[APP][Pro] WhatsApp - Simple. Reliable. Private
I’ll have a look, thnks!
@Rrrr thats not needed anymore. That was fixed in a couple of versions ago
See: [APP][Pro] WhatsApp - Simple. Reliable. Private - #286 by martijnpoppen
@TMS_TMS can you add a 10 sec delay between the snapshot and the whatsapp card?
Then run it and send a new report after that
Sorry I did not see that earlier. I tested and your internal queuing works well.
did that, but same result alas.
report sent!
@TMS_TMS report looks good.
I’ll make a update with some extra logs so we can pinpoint the issue :slight_smile:
After the last update it does not work again, the phone has been disconnected again. Re-pairing again gives the problem that it cannot be connected. Before the last update there was a delay of over 5 seconds before a message arrived. By comparison: Telegram within a second. In short it is very unreliable. For now, back to Telegram.
@Ad_van_Liempt
Nothing in the update changed the pairing. Probably this is caused by the restart of the app during update
As already mentioned several times. Whatsapp is not Telegram. Nor has Whatsapp a official API so ofcourse it takes time. It’s using WhatsappWeb in the background to send messages, so there will always be a delay.
Since the latest version i’m unable to send messages any more. No errors are displayed and the flow did run successful but no message is send.
I’ve created a diag code - cf20b4f9-1ce5-402f-9739-cc6afe2b5a6d
@Jeroen_W As I see in the logs your conenction is disconnected. Repairing the device should fix that. I’ll check why this happened :slight_smile:
Thanks, i’ve tried to repair but it’s stuck at loading for 5 min now :frowning:
@Jeroen_W are you trying via the webapp?
Tried webapp and via android phone app
Can you send a new report?
here you go a9fcf2f7-81af-4ec0-a005-76111e1a0e3d
Thanks @Jeroen_W
Indeed something wrong! will make a fix :slight_smile:
New app update (:green_square: LIVE: 1.19.4):
Changelog:
NEW:
1: None
FIXES:
1: FIX: startup Whatsapp Client on startup of app to prevent first message not being send
2 FIX: add extra logs to image sender
3 FIX: repair
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
@Jeroen_W see release above :wink:
Wow that’s quick :slight_smile: unfortunately repair is still stuck on loading
29866d53-86cc-429f-b515-3666d940c430
@Jeroen_W yep coreect. Updated to 1.19.4 can you check that one? :slight_smile:
