[APP][Pro] VW Group Vehicles - Access your vehicle data via the EU Data Act portal for VW, Audi, Škoda, SEAT, Cupra and Bentley
Hi Andi,
Thanks for the quick reply. Here are the Data Act exports you asked for, two from each car (ID.3 and ID. Buzz, 17/11 and 20/11):
https://drive.proton.me/urls/P4QC517AEW#z6mJWLGVwobf
I’ve removed the VIN and user ID. Please let me know when you’ve downloaded them, so I can take the link down again.
A few things that might help:
  • Buzz: in_cabin_temperature.temperature reports 0 while measurement_state says VALID. That might be relevant for the cabin temperature fix.
  • Buzz: hvbatterytemperature min/max is in there.
  • ID.3: the 20/11 export includes BMS capacity, energy content (max/current) and cell temperatures.
Thanks for the great work on the app!
Mads
Hi Mads,
Thank you so much for the beer, that’s very kind of you! :beer_mug: And thanks for the four exports. I’ve downloaded them, so you can take the Proton link down now.
They were really useful, and version 0.2.1 with the fixes is now live: VW Group Vehicles | Homey
  • Battery values (ID.3): temperatures, capacity (152.2 Ah), cell voltages, pack voltage and current all come through with proper units and look right.
  • Charging timer: both cars send several start/finish times at once, including old ones. The app used to take whichever came last, so it could mix two timers or show one from days ago. Now it shows the next timer that hasn’t ended yet, with its own finish time, and leaves the tiles empty when there is none.
  • Charge mode (Buzz): your Buzz reports two different modes at the same time (“preferred charging times” and “immediate”), so the tile kept switching. It now stays empty when they disagree. Do you know which one is actually set in the car? That would help me decide which one to trust.
  • Cabin temperature (Buzz): the 0 is flagged as VALID, but in VW’s data dictionary a raw 0 means −46 °C, the bottom of the scale. So the Buzz doesn’t seem to send a real cabin reading, and the tile stays empty instead of showing −45.4 °C.
  • Energy content (ID.3): your 20/11 export has 526 / 425 without a unit, probably 52.6 / 42.5 kWh. That could become a battery-health tile once I can confirm the unit.
Thanks again for the help and the beer!
Andi
Hey Andi,
that was quick - impressive :smiley:
Reg. the different modes in Buzz. I am not sure which was set, i know i have been switching back and forth between the two modes, so it could be either at the times of export. I can do a new data pull, with a certain mode set, if that helps?
Let me know if any other things could be helpful
/Mads
Hi Mads,
Thanks! Yes, a new data pull with a known mode would help a lot. Your Buzz sends the charge mode under two different fields, and only one of them seems to follow what you set in the car. Two exports would tell me which one:
  1. Set the Buzz to immediate charging, wait until the car has synced (open the VW app and check it shows the new mode), then request an export.
  2. Switch to preferred charging times, wait for the sync again, and request a second export.
Please write down which mode was set for which export. Once I know which field is the right one, the tile can show the mode again instead of staying empty.
Two optional extras, if it’s easy for you:
  • Charging timer: in one of the exports, have a timer set that starts later (e.g. overnight). That lets me confirm the timer tiles show the upcoming time correctly.
  • Energy content (ID.3): an export together with the state of charge the car shows at that moment. That would help me confirm the unit of the energy values (526 / 425 last time), which could become a battery-health tile.
No rush, and thanks again for helping out!
Andi
Hi Andi,
Here are the new exports: Proton Drive
  • Buzz1: immediate charging, unplugged
  • Buzz3: preferred charging times (09.00 - 16:00), plugged in
  • ID3: the car showed 75 % when I took it
I noticed that the change showed up in the VW app right away, but it took a few hours before it was in the export. My first try still had the old mode, so I waited overnight.
Let me know if further tests are usable - happy to assist!
Thanks
Mads
Hi Mads
I’m having issues with your files: :sos_button:
Andi
Hey!
I’d like to start using the app to add my 2021 Cupra Formentor to my Homey Pro 2026. I’ve gone through all the steps, however I’m unfortunately not getting any data in my files, so my Homey isn’t receiving any information either. Anyone have a solution for this? My car has an internet connection and the profile sharing the most data is enabled. I’ve already deleted and reconfigured the app and the car once.
Hi Andi,
weird. Just used Claude to anonymise them, and nothing else. I’ve tried uploading the .json files to the same folder. Hope that’s better?
/Mads
Hi Mads,
Thank you, that was exactly what I needed! I’ve downloaded the files, so you can take the link down.
Version 0.2.2 with the fixes is now available as a test version: VW Group Vehicles | Homey
Charge mode: your test settled it. With immediate charging set, both fields say “immediate”. With preferred charging times set, one field follows your setting and the other stays on “immediate”. So when they differ, the app now shows the one that isn’t “immediate”. On your Buzz that means “preferred times” instead of an empty tile.
Cabin temperature: your exports proved me wrong here. The Buzz sent -3 on a -4 °C night and 11 after a drive. VW’s data dictionary describes an encoding in which -3 is impossible, so the car simply sends normal °C. That also explains your original -45.4 °C: it was really 6 °C, converted wrongly by the app. 0.2.2 shows the cabin temperature as the car sends it.
Charging timer: works as intended. Buzz3 shows the next charge at 10:00–11:20 your time, inside your 09:00–16:00 window.
Energy content (ID.3): 374 of 526 would be 71 %, while the car showed 75 %, and the earlier export didn’t line up either. So I’m leaving that one out until it’s clearer what the numbers mean.
If you install the test version, I’d be glad to hear whether the cabin temperature and charge mode now match what the car shows.
Andi
Hi Andi,
Test version installed. I’ll update you once some data starts to arrive.
Another thing I just learned via you: preferred charging apparently works differently on the two vehicles. Maybe you know something about the reasoning. On the ID.3, if I set a preferred charging time of 00:00–06:00, it starts at 00:00 and stops when the SoC reaches the requested level or at 06:00, whichever comes first. On the ID. Buzz, with a window of 09:00–16:00, it chose what looks like a random slot within the window, in this case 10:00–11:20. No departure time was set, as far as i remember. Do you know what it bases its decision on? It doesn’t know my electricity prices, so from my point of view it looks random.
I’ve had several nights where I thought the Buzz “forgot” to wake up and charge, but maybe it had just picked a later slot within the window. I can’t see the chosen slot anywhere in the menus. It just shows “Charging paused”.
Thanks again for your efforts!
/Mads
Hi Mads,
Thanks for installing it!
About the preferred charging: VW doesn’t document how the car picks its slot, so I can only tell you what the data shows. In the Buzz export from the 24th there’s a field charging_scenario with the value “charging to departure time – waiting”. So the Buzz seems to believe there is a departure time, even if you don’t remember setting one. With a departure time, the car plans the charge to be done by then instead of starting at the beginning of the window. Without one, it behaves like your ID.3 and starts right away. It might be worth checking the departure times and the charging location profile in the Buzz (or in the VW app); perhaps one is active there. That would also explain the nights where it seemed to “forget” to charge: it may simply have planned a later slot.
The app’s two timer tiles now show the planned start and end, which the car’s menus apparently don’t, so you can see in Homey when the Buzz intends to charge.
One thing you could help me check: the export said the charge would start at 09:00 UTC, which is 10:00 your time, and that’s what the app shows. But your window starts at 09:00, so it’s possible VW actually sends local time and labels it as UTC. Do you remember, or can you see in the VW app’s charging history, whether the Buzz started charging at 09:00 or at 10:00 that day? If it was 09:00, the timer tiles are an hour off and I’ll fix that.
Andi
Hi everyone,
I’m having an issue with the API data for my vehicle.
As you can see in the attached screenshot, the API was last updated on 26 November 2026 at 11:12, but the actual vehicle data shown is from 25 November 2026 at 23:08.
This means the API data does not seem to match the latest information from my car.
Is anyone else experiencing this issue? Does anyone know why the API is not retrieving the latest vehicle data, or how I can fix this?
Any help or suggestions would be greatly appreciated!
Thanks in advance!
Hi Rick,
Thanks for the screenshot. This is actually how it’s meant to work. The two tiles show two different things:
  • “Laatst bijgewerkt” (last updated): when the app last fetched data from the VW Group portal. It checks regularly, so this is recent.
  • “Gegevens van” (data from): when your car itself last sent data. That’s the age of the values you see.
The portal can only pass on what the car has transmitted. A parked car that’s asleep sends nothing, so if the car hasn’t been driven or charged since 23:08 last night, that is still the newest data available, however often the app asks. New values arrive after the car wakes up again (driving, charging, or using the manufacturer’s app), and then usually with some delay on the portal side, sometimes a few hours.
If you want Homey to react to old data, you can use the flow condition “Reading is older than …”.
If “Gegevens van” still doesn’t move after you’ve driven or charged the car, please send me a diagnostic report from the app and I’ll take a look.
Andi
Hi Andi,
Thanks for your explanation.
The problem is that I want to use smart charging through Homey, based on cheap dynamic electricity prices. For this to work properly, Homey needs accurate and up-to-date information about my car’s battery level.
However, the battery percentage displayed in Homey does not match the actual battery percentage shown in my car. I also have the impression that the data is significantly delayed and not updated frequently enough.
This makes it difficult for Homey to determine when and how much to charge my car, as it is making decisions based on outdated information.
Is there anything I can do to make sure Homey receives more recent battery data? For example, is there a way to force the car to update its data or to make the app retrieve the latest information more frequently?
I understand that the car may go into sleep mode, but for smart charging this is quite an important limitation.
Thanks in advance for your help!
Best regards,
Rick
Hi Rick,
I understand, and you’re right: for price-based smart charging this is a real limitation. Unfortunately it can’t be solved in the app.
This app uses the EU Data Act portal of the VW Group. It is a data-access service, not a live connection to the car:
  • The portal only receives data when the car itself sends it (driving, charging, waking up), and then often with a delay of minutes to a few hours.
  • It is read-only. There is no command to wake the car or request a fresh reading, so neither the app nor Homey can force an update.
  • The app already adjusts how often it checks to when the portal delivers new data, and the “Update data” button fetches immediately. Asking more often doesn’t help, because there is simply nothing newer on the portal yet.
That’s also why the percentage in Homey can differ from the car: Homey shows the last value the car reported, together with its time under “Gegevens van”.
What works well in practice:
  • Let the car stop the charge. Set the charge limit (e.g. 80 %) in the car, and let Homey only decide when the charger is switched on, based on the prices. The car stops by itself at the target, however old Homey’s percentage is.
  • Use the charger’s data while charging. If your wallbox is in Homey, its power and energy figures are live. You can estimate the charge added from the last known percentage plus the kWh delivered.
  • Check the age in flows. With the condition “Reading is older than …” a flow can fall back to a safe default (e.g. charge in the cheapest hours anyway) when the battery value is too old to trust.
If you need the state of charge in near real time, you’d need an integration that uses the manufacturer’s own connected-car service (the one behind the brand’s app), which can also wake the car. The Data Act portal doesn’t offer that.
Sorry I can’t give you a better answer here!
Andi
Hi Rick,
Until fix data issue, my Homey flow works with a safety fallback.
Homey checks the car every minute and verifies that the car is physically connected through the Easee charger. It also checks whether the CUPRA battery reading is newer than 60 minutes.
If the battery data is fresh, Homey calculates how much charging time is needed. For example, if the battery is at 70%, it estimates the required charging time and searches for the cheapest continuous period before 07:00. On Saturdays, the deadline is 06:00.
If the CUPRA reading is old, missing, undated, or unavailable, Homey does not trust the percentage. Instead, it reserves a conservative four-hour charging window and chooses the cheapest continuous four-hour period before the deadline.
So it does not simply choose one cheap hour. It chooses enough consecutive cheap hours to make sure the car can charge safely before departure.
If the car shows 100% but the reading is stale, Homey still uses the four-hour fallback. If the battery reading is fresh and really shows 100%, Homey will not charge.
Homey can also use solar surplus before the planned charging period. It starts only when there is enough solar export and pauses if the house starts importing too much electricity.
Easee is used to confirm whether the car is really connected and whether charging has actually completed. This prevents Homey from relying only on outdated CUPRA data.
Best regards,
