Please try: VW Group Vehicles | Homey
Yes, working. Thank you.
If you need me to test anything else please let me know.
I managed to add the device, and the data is being retrieved and is visible in Homey, but locking and unlocking the car from the Homey mobile app doesn’t work. Has anyone else encountered this issue?
Hi Grzegorz
This will never work - sorry
EU Data Act data is read only ![]()
Andi
Indeed, it doesn’t work.
Hey guys,
I did update to the beta version due to log-in problems at Cupra/Seat (as stated above)
Does any know why i’m seeing data from almost 2 days ago, or point me in the right way.
Thank you guys
Cupra Formentor VZ eHybrid 1,4L 2022
Hi Steefaaan,
Good to hear the sign-in works again with the test version. You’re the first CUPRA owner to confirm it.
About the old data: the app shows when the car itself measured the values, not when the app last fetched them. So if it says “Data from” two days ago, the newest dataset VW delivered contains readings from then. Several users currently see the VW portal running one to two days behind: it keeps putting new files online every 15 minutes, but they contain the same old snapshot. The app can’t make the car report sooner.
To check whether that’s what happens in your case, could you send me two things?
App Logs: Homey app → More → Apps → VW Group Vehicles → Configure app → App Logs tab → Copy.
Debug JSON: same page, Debug Data tab → your car → Copy. Please replace the vin and user_id values with before posting.
The log shows how old the data is when it arrives (“The vehicle last reported … h ago”), and the JSON shows which reading carries which time.
Andi
Hello Andi,
Thanks for replying this fast!
Edit: Removed
And
Edit: Removed
I hopefully gave the right info, I did minimize the length of the logs in orde to keep the posts readable. Thank you ![]()
Hi Steefaaan,
Thanks, that was exactly what I needed.
First, good news: the log confirms the new CUPRA sign-in works. The app logs in, and it fetches a new dataset from the VW portal about every 15 minutes.
The problem is what’s inside those datasets. Every file VW delivered today contains the same snapshot of your car from Monday evening: most readings at 19:43 UTC on 26 Oct, and the battery level even earlier, at 17:11 UTC. VW keeps repackaging that snapshot under new file names. The app notices this (“No newer vehicle readings than before”) and keeps showing “Data from” Monday instead of pretending the data is new.
So the app is up to date with the portal, but the portal has heard nothing from your car since Monday evening. Two questions to narrow it down:
- Have you driven or charged the car since Monday evening? The car usually sends new data after a trip or a charge.
- Does the CUPRA app on your phone show newer values (battery level, last parked time) than Monday evening?
If the CUPRA app is current but Homey isn’t, VW’s data portal is running behind. Another user saw a delay of almost two days with it this week, and it caught up by itself. If the CUPRA app is also stuck on Monday, the car isn’t reporting at all. In that case, check that privacy mode is off and the online services are active in the car.
Recreating the data request in the portal won’t help, by the way. It doesn’t speed up the delivery.
Andi
Thank you for this incredibly detailed response, and apologies that you’ve had to share this information several times already. I hope Volkswagen sets things right again soon.
In the Cupra app, for instance, the electric range is displayed correctly, and the data is up to date. The car is driven every day and charged every few days.
If I can assist by providing new data or by testing a beta version of the app, please let me know—I’d be happy to help.
Thanks again for your time.
When I plug in my ID.7 to charge, the app doesn’t show that it’s charging. Does anyone else see charging parameters in the app?
Same here. I do see the updates every 15 minutes on the https://eu-data-act.drivesomethinggreater.com/ site though. Homey app seems not to be polling it.
It stopped working today. I’m getting the message “Could not fetch vehicle data.”
Stopped for me too
new version is LIVE - please check if it works
