Hi Oreste, as you know the Vitrum Switches support the Central Scene V3 class and buttons can be configured independently in this mode by setting the corresponding parameter (1 to 6) either to 7 (EP_SCENE_PB), 8 (EP_SCENE_TOGGLE), 9 (EP_SCENE_PB_TOGGLE) or to 26 (EP_CENTRAL_SCENE). Is this supported already in your App? Can the scene activation events be caught in rules and reacted upon?
Not in the current version but you can set zwave raw parameters and archive same results.
If you have some documentation to share, i’ll add those settings in the app
Yes I have it. Please use the following link to download it: Nextcloud
Link will expire in 5 days.
Just got it. Thanks.
I’ll add the feature in the next days. Busy time at work.
Oreste
Alexus,
i had time to better look at the documentation and i’m afraid that scenes works only on Vitrum products. There is no such scene functionality in Homey.
What you are referring to can be easily archieved by building a flow for every button and define scene logic within the flow.
This is what i’m doing here and it works correctly.
Please tell me if you are referring to something different.
Oreste
Hi Oreste,
I will explain what I have tried to achieve in detail: I have set one button in pushbutton configuration (value 3). I have created a flow and wanted to have it run each time the button is pressed. But for some reason Homey is not able to detect such events. I have tried to same configuration with zwave2mqtt and I am able to catch the push button events. So I decided to give it a try and configure the button in SCENE_ACTIVATION modes (values 7,8 and 9) or in CENTRAL_SCENE_MODE (value 26). Again I wasn’t much successful in detecting any events in these modes to be able to trigger a flow. With zwave2mqtt I am able to catch everything. So I am not sure whether it is an App issue or if Zwave on Homey does not support SCENE_ACTIVATION and CENTRAL_SCENE_MODE command classes.
Or maybe I am missing something…
Hi Oreste,
any update on my last comment??
Dear Oreste,
is it possible to contribute to the code of the Vitrum App?
I would really like to give it a try on enabling the SCENE stuff for such devices in rules. I would really appreciate if you can point me out to the right direction.
Here’s an example of what we are seeing today on 2 identical devices (6 button Vitrum):
what could be the cause of this?
Many thanks
Hey yoy all. Im new here but after reading your sybject I have decided to buy Homey Pro to finaly set up Vitrum at home(had it for years installed but never set up) I managed to set up everything but 1 console has not been recognised as vitrum and got added as generyc zwave. Could you help me with that. How could I change it to 4 buttons Vitrum? i have seen @Oreste_Dimaggio has fixed similar problem for others
Product ID is 4099 and product type id is 28930. thanks!!! ![]()
Jakub, send me a picture of the switch and i’ll add those IDs in a newer version of the app.
Then you’ll be able to add the last one wich has been added as Generic Zwave just like you did with the others.
Looking forward to it
All numbers I have found. Thanks
2330031
01E04H030
651055578G
OP192942-1936
It seems a Vitrum IV Triac.
I’ll Plan to add the Product and Vendor ID in few days.
I’ll keep you posted.
Thanks. No hurry:)
I Just updates the app. Please try your device by adding a:
Vitrum IV Triac EU
Let me know of everything world correctly!
Hei Oreste,
I am getting msg
Unable to connect. Missing multichannelnode 5 on node.
Cheers
Jakub
please provide more info.
When this happens? when you try to pair the new device?
Can you send me a screenshot?
Tnks
Yes when I try to pair them.
M NO: 0047 483-483-66
@: jakubwitek@gmail.com
The information contained in this message may be CONFIDENTIAL and is intended for the addressee only.
Any unauthorized use, dissemination of the information or copying of this message is prohibited.
If you are not the addressee, please notify the sender immediately by return e-mail and delete this message. Thank you.
I just published version 4.0.2 which should have fixed the issue.
Once Homey will approve it, please try it out and let me know.
Be sure you are testing version 4.0.2
Hei,
thanks. it is working now
cheers
Jakub
Hi Oreste!
A few more devices currently showing as unknown, from Vitrum:
1 - 01E06H042 - Vitrum EU VI Satellite
Product Type ID: 29026
Product ID: 4195
2 - 02E02H011 - Vitrum EU II Single Shutter
Product Type ID: 28801
Product ID: 3970
If you’d be so kind to add them and release a new version of the app, it’d be most welcome.
Cheers!
