[APP][Pro] Verisure
Thanks! Worked fine for me in version 3.2.4 (220714).
Have you found a solution to add more than The «home» device?
Im still struggeling, just: Cannot read properties of undefined (reading ‘data’), on all devices (eks home unit)
Hej
Unfortunately no solution yet. Only Home and nothing else. I have tried all of the above and several times and with different users and no success.
So for now I am hoping that it will be solved :crossed_fingers:
If I find one i will share :blush:
Regards
R Noel
After I was able to add my devices with the 3.2.3 upgrade and after the 3.2.4 fix for “401 request failed” error things seems to work quite ok for me, however, the 401 error now always seems to appear once after not having used the app for a while and for example turning on a switch, but then trying again it works (this is definitely a pattern).
So I would say it’s partially fixed but not 100%. Flows seems to work, but this morning I noticed one of the switches had not turned off, so maybe it’s the same there, first request fails but then the following works. :man_shrugging:
I’m super happy to see this Verisure app for Homey and big part of why I bought the Homey in the first place. It’s very very close to being perfect for me. Thank you! :slight_smile:
@norenz i have the same issues.
Currently on version 3.2.4 and the first click on a SmartPlug says 401 error but the second click works.
Non of my flows are working.
Seems like the app is signing my account off after awhile.
Is this a known bug to you?
I still have the same problem, can’t log in.
Have you verified that you can login on Verisure MyPages and is NOT prompted for a 2FA (SMS) code?
When this worked for me (a lot of testing made my account suspended for a while), then after uninstalling and reinstalling the app, login was successful.
Strangely enough, after Homey was updated to 8.0.3 I have not seen the 401 errors any more. Right now everything seems to work fine. :+1:
I will not disable the 2FA security for the Verisure alarm. This makes the alarm system vulnerable for attack/hacks as well as the Homey system since it is integrated in Homey.
@norenz The app worked with 2FA security before upgrading. Can I get a link where I can roll the app back to the old working version?
I don’t use the other devices…
Anyone having problem with the app not updating status of the devices after a while? Restarting the app temporarily fixes the problem.
I have the same problem.
Me too
After around 1 day the app cant uppdate agen. Need to restart te app and log back in.
Same here. I have to restart the app every 2-3 days. Can I send a diagnostic report? Thanks
For all of you having issues where the system stops getting data, please install the beta where I will push fixes until problems are solved: Verisure App for Homey | Homey
Please kindly provide me with feedback if it solves your issues so that the beta can go live.
Then i have added the beta. Il update tomorrow about that status around the components. (for now it is working). But still got the problem with that i cant activate the alarm .
Did you entered the PIN code in the settings for the specific user?
yes i did. I get log in success then i save it and get saved ok. Il try to re add the alarm part agen
geting error when activating "could not change status to “armed away”
that i got after i did restart the app and readding “home”
