[APP][Pro] Vent-Axia - Control your Vent-Axia Svensa
Nederlands topic: Nieuwe app: Vent-Axia bedien je Svensa
Control your Vent-Axia Svensa locally over Bluetooth: continuous operation, boost, pause, the three automatic sensitivities, and its humidity, air quality, light and temperature sensors in your flows.
The fan accepts only one Bluetooth connection at a time. Close the Vent-Axia app on your phone before you start. If it stays connected, Homey cannot reach the fan. If closing it is not enough, switch Bluetooth off on your phone. The same applies to any other hub that talks to this fan.
  1. Remove the magnetic front cover.
  2. Make sure the fan is powered on and running.
  3. Tap the power touch button on the front right. The other buttons will light up.
  4. Press and hold the bottom button (the Wi-Fi symbol) until it starts blinking.
  5. Press “Fetch PIN” below within a few seconds.
Can’t connect.
@Jacques_Derks the PIN code isn’t printed on the Svensa, so the Homey app retrieves it directly from the fan during pairing:
  5. In Homey, press “Fetch PIN code”.
If you already have a Bluetooth connection with, for example, an app on your phone, please temporarily turn off Bluetooth on your phone. Only one Bluetooth connection can be active at a time.
