Hey @Lasse_K, I totally understand your frustration with the contact sensor showing up as unknown. It’s likely related to the recent improvements in Zigbee support. If everything is working fine, that’s a relief! But if you want to clear that “unknown” label, re-pairing could definitely help.
@robertklep, you’re spot on about the functionality still being there despite the unknown status. It can be a bit quirky with some devices, but as long as it’s doing its job, that’s what counts! If you start seeing any missing readings or anything unusual, feel free to share the app logs here, and I’ll take a look at the data points for you.
But AFAIK Tuya uses its own clusters (not the generic clusters included in ZigBee), right? That wouldn’t work in that case as I believe Homey only added support for the generic clusters.
Hi Dylan I’ve reconnect the Contact sensor again and there is no data reception from the sensor I did it this morning but it stays at 56 Years ago.
Diagnostic code- 0c838576-ae7b-4626-ae08-06dab019f1fb
v5.11.186: Corrected model strings for OpenRouter and Cerebras to resolve 404 errors., Monthly enrichment added 3183 validated fingerprints across 193 drivers.
Covers a huge range of Tuya devices at this point.
Hi Dylan, all soil humidity sensors (about 7 different types and 15 devices) have been working perfectly for a few days now. As well as some motion sensors. Thank you very much for that!
Next up are rain sensors and plugs.
Who can recommend a good presence detector for me? Need some there.
That’s awesome to hear! Glad the mesh is stable and those 15 sensors are finally behaving.
For presence, you definitely want to look at mmWave sensors so you don’t get left in the dark when you’re just sitting still. Here are the best bets:
Sonoff SNZB-06P: Cheap, Zigbee, and works great with Homey.
Aqara FP2: The “gold standard” if you want to map out specific zones in a room (WiFi).
Tuya mmWave: Plenty of these work with the app now, just check the thread for specific models.
Just a heads-up: these usually need USB power, so no batteries for these ones!
Good luck with the rain sensors and plugs—keep me posted on the thread!
v5.11.195: Fixed dual-temperature display issue on TS0201 climate sensors by removing default probe temperature., Resolved a critical crash caused by phantom getDeviceConditionCard and getDeviceActionCard SDK3 methods., Corrected absolute ZCL action handlers to use native TriggerCapabilityListener for proper gang action support with hybrid DP translation., Enabled physical flow triggers for
v5.11.196: Fixed pairing failures for 151 devices using uppercase manufacturer IDs by enforcing strict case-insensitive fingerprint matching., Resolved capability mapping and endpoint routing issues in multiple bulb, wireless button, and air quality sensor drivers., Added and updated fingerprints across 20+ drivers including bulb_rgbw, bulb_tunable_white, button_wireless_*, and `air_quality_
v5.11.197: Added 3 new device fingerprints to driver mappings, enabling direct support for recently released Tuya hardware., Integrated 2,141 upstream device profiles into the compatibility database, improving automatic pairing accuracy for sensors, switches, and climate controllers., Updated manufacturer and product ID matching to recognize newer Tuya OEM variants, reducing manual pairing steps a
