[APP][Pro] Universal TUYA Zigbee Device App - test
v5.11.143 is up on test.
v5.11.142: Resolved issues related to device fingerprints and driver compatibility., Added 3182 new fingerprints for enhanced device support., Now supports a total of 189 drivers, improving overall device integration.
Covers a huge range of Tuya devices at this point.
v5.11.144 is up on test.
v5.11.143: Fixed issue with 4 gang wall switch (_TZ3000_xabckq1v) that stopped working., Added new fingerprints for devices: dlnraja, example, vision.
v5.11.145 is up on test.
v5.11.144: Fixed issue with 4 gang wall switch (_TZ3000_xabckq1v) that stopped working., Added support for new device fingerprints, increasing total to 3880.
Just pushed v5.11.146 to the test channel.
v5.11.145: Resolved syntax errors and missing methods in drivers affecting device functionality., Added support for 191 drivers and 3880 fingerprints, enhancing compatibility with various Zigbee devices.
New build out — v5.11.147 on test.
v5.11.146: Fixed ‘Missing Capability Listener’ error during initialization., Total drivers: 191, Total fingerprints: 3185
v5.11.148 is up on test.
v5.11.147: Fixed issue with 4 gang wall switch not working (FP: _TZ3000_xabckq1v, example, vision)., Added new fingerprints for improved device compatibility, Total drivers: 191, fingerprints: 3185.
New build out — v5.11.149 on test.
v5.11.148: Fixed issue with 4 gang wall switch (_TZ3000_xabckq1v) that stopped working., Added support for new device fingerprints, increasing total to 3880.
New build out — v5.11.150 on test.
v5.11.149: Resolved issues with 4 gang wall switch not functioning as reported by users., Added support for new device fingerprints, increasing compatibility with additional Tuya Zigbee devices., Updated driver database to include 191 drivers and 3185 fingerprints.
New build out — v5.11.152 on test.
Universal Tuya Zigbee app v5.11.152 fixes rain sensor pairing and resolves critical SyntaxError crashes.
TZ3000_tzvbimpq not working anymore on this version.
diag report: 94afaece-88d1-46d0-a8bf-481a756f480c
IR remote (_TZ3290_7v1k4vufotpowp9z) still not working. Button “learn IR code” is activating the IR remote now (blue light turns on) but no IR code is learned. Homey gives a timeout error.
diag report: be6cbc7e-6a23-4097-9260-b9a326eea94a
Hi. Motion sensors TS0601 (TZE200) after update not working anymore.
In V5.11.150 most switch models have recovered so are reachable now.
Except the TZ3000_jl7qyupf, this one keeps giving error message “Missing Capability Listener: onoff”.
V5.11.152 is not pushed to my Homey yet so can’t see if that solves my issue…
You can always install the latest test version of an app yourself, by going to the app store page and hit install: https://homey.app/en-nl/app/com.dlnraja.tuya.zigbee/Universal-Tuya/test/.
152 hasn’t been pushed to the app store, so even with manual install it will still install 150.
Loratap 3 button remotes TS0043 - _TZ3000_famkxci2 not working anymore. (Homey warning Could not get device by id)
Loratap 4 button remotes TS0044 - _TZ3000_ee8nrt2l not working anymore. (Homey warning Could not get device by id)
Motionsensors TS0601 not working anymore. (Homey warning Could not get device by id)
Is there possibility to downgrade Universal Tuya app?
A „downgrade“ is only possible in case you happen to have downloaded the appropriate source code and install it as your development version
Just pushed v5.11.154 to the test channel.
v5.11.152: Fixed rain sensor pairing by removing strict endpoints., Removed emoji characters from all driver.js files to prevent SyntaxError crashes on Homey Pro.
Ver.154. Contact sensor installs as unknown Zigbee, BUT has full correct function.
Probably the recently improved generic Zigbee device support that’s handling it.
