[APP][Pro] Ubiquiti UniFi app
I have accactly the same problem,
after ~5m the app stops working. Only restarting the app helps
Yeah, only restart helps :frowning: I hope the app well get a update.
I have the same issue, will an update help? Or is there another problem?
Same problem for me - unifi Cloud Key2 plus
Works fine and after a few minutes it crashes.
Update: I have 2 Homeys, the original and the Pro.
At the original the app is working fine… so the problem is not related to the Unifi setup :face_with_raised_eyebrow:
Update2: just installed this experimental test version 2.1.2 and for now seems to work fine again:
I came here for the obvious reasons I could not get the configuration working. Scratching my head and reading several posts and trying a bunch of stuff…
Only because that damn checkbox is not a box but just a check mark. Come on, make the ā€œunifios deviceā€ checkbox a bit more clear that it is actually something needed to click. I just read the label and made sure my port was 443.
I’ve noticed that the card trigger ā€œWifi Connection Lostā€ or ā€œConnection Lostā€ takes a very long time to trigger.
When i disable my wifi for example my phone:
  • I see in the debug almost instant that my phone has disconnected. See below.
  • The device connection status is almost instant set to no
  • When I run the flow manually it works instant.
I don’t understand why it take minutes to trigger the disconnect card :frowning: Has anyone else experience this?
I this a possible bug?
6/30/2022, 10:03:43 PM : [debug] - device.alarm_connected: false
6/30/2022, 10:03:43 PM : [debug] Flow condition.wifi_client_connected
6/30/2022, 10:03:42 PM : [debug] - device.alarm_connected: true
6/30/2022, 10:03:42 PM : [debug] Flow condition.wifi_client_connected
6/30/2022, 10:03:42 PM : [debug] Accesspoint AP has 1 clients
6/30/2022, 10:03:42 PM : [debug] - regular trigger
6/30/2022, 10:03:42 PM : [debug] Triggering flow last_device_disconnected with tokens [object Object]
6/30/2022, 10:03:42 PM : [debug] Triggering last_device_disconnected with state [object Object]
6/30/2022, 10:03:42 PM : [debug] Accesspoint has 0 clients
6/30/2022, 10:03:42 PM : [debug] Analyze AP flows
6/30/2022, 10:03:42 PM : [debug] Clients connected: before:2, now:1 -
6/30/2022, 10:03:42 PM : [debug] Checking for *_device_o(n|ff)line
6/30/2022, 10:03:42 PM : [debug] Triggering flow a_client_disconnected with tokens [object Object]
6/30/2022, 10:03:42 PM : [debug] - device trigger for  **Phone**
6/30/2022, 10:03:41 PM : [debug] Triggering flow wifi_client_disconnected with tokens [object Object]
