[App][pro] Tuya Zigbee garage Door opener
Hello ,
I wanted to connect my Tuya Zigbee garage door opener to homey pro 23 and couldnt find any app that would work for me. trying it through Zigbee2mqtt gave me capability errors. So, i created my own app. I been testing it for a week and seem to work. I want to publish in Homey App store just in case there are more people with same issue. Here is the link to test version of the app. If it works, i will apply to publish live in app store.
install it and let me know if it works for you. i tested this with LoraTap Zigbee garage door opener with wireless contact sensor. I have also added other Tuya based Zigbee openers Device ID’s i found in Zigbee2MQTT database that use same endpoints. In thoery, if yours work with Zigbee2MQTT, it should work with this app.
credits: Some of the code is inspired by JohanBendz / com.tuya.zigbee
my device is identifed as TS0601 / _TZE20C_3oycaicw and is not supported
I updated the app. please try installing new version
Thank you! It works perfectly with the garage door opener I bought from Loratap in combination with the open/close sensor.
