Good afternoon,
My devices just out of a blue became unresponsive today… removed them, reinstalled app, went thru app setup again and when I try to install my devices I get this:
Any clue how can I get this work again?
Thanks
J.
Good afternoon,
Thanks
J.
Same for me
Soooo frustrating :-/
Indeed, hope for a solution asap
App works fine here, so it must be a setting.
First try adding devices with the web app.
It shows usable error numbers if I’m right. These numbers and possible fixes, can be found in post 1 of this topic.
Also, make sure to select “Use Official only” at the Desired API field
Also, check if the free of charge iot core supscription is still valid, it needs renewal each 6 months:
I extended IoT core, that fixed it! Many thanks!
Thanks guys for your advice. All good now. Have a good night, J.
Hi Kringloper,
Any solution for this ?
I have same issue with radiant heater.
Same fault.
hello,
i can’t get my 2 led ribbons to work on homey, which works fine on the phone app. here’s a screenshot of the tuya cloud app.
thanks for your help.
it’s OK now, I hadn’t done the IOT extension on tuya iot
thank
Does anyone use the Tuya energy meter clamps? Can these be used with this app?
Thanks
Do you already own these? Do they work properly? I am looking to measure power consumption of a two phase group (typical Dutch “kookgroep”)
