There is a new test version 1.1.0. In this version generic triggers and action cards are added. You can receive all messages send for devices with trigger cards. Also there are now action cards to send commands to you device. On this way you can interact with not directly supported devices are commands. Combine it with the virtual devices app and you can control most of your devices. It’s a function for advanced users, there is no validation when sending a command to your device.
To get the device id’s, commands and possible values you can create a flow with the text event received trigger card. This card is returning device id, command and value for each action. Log the returned values to log app to know the commands of your devices, deviceid’s and possible values.
Use the boolean and number cards when values are boolean or number. Otherwise you get an error.
