[APP][Pro] Trashcan Reminder 2.0
You need to remove the old one and select the afvalkalender Utrecht. It should be there.
You mean this one? This is the only one with Utrecht in it.
I can’t find “Afvalkalender Utrecht”
It looks like it doesn’t give me any data, or do I have to wait a while?
This is what you should see (when running the test version - just took a random address in Utrecht):
So update the source, update your postalcode + number, press “Save changes”. Then, if you want to see the new data, scroll down all the way to the bottom of the page. Select the “Refresh Debug Information”, then you should see the new dates.
It might take a restart of the Homey app on your phone to see the new dates in the widget.
Mij postal code worked, but I don’t get more that the debug data GFT. I don’t see
PAPIER in the list.
You can scroll down in that list. For my trial postal code it lists papier as well.
See DM
Gemeente Utrecht has been tested and approved now.
Thanks Robert
I’m using this app for a long time without any problems. But now my postal code/ address isn’t recognized anymore. I use Afvalkalender Reinis for the city Hellevoetsluis in the Netherlands
I used this app quite some time, but now Breda changed from ‘Mijn Afvalwijzer’ to the Afvalservice app so it is not working anymore. Any help is appreciated.
Ah, it’s that wonderful time of the year again. For everyone reporting that details are not working. Please provide the following details (best would be in GitHub, but you are also allowed to post it here or in a PM):
  • the url of the afvalkalender
  • an example postal code and house number that yields a result on the url
Then I can have a look, thanks!
Thank you, they are using an app only: Afvalservice app | Gemeente Breda
Starting the app, you login with your postalcode and housenr (4822RL and 19)
Then you see the dates. Hope this helps?
Best regards, Jan
