TomTom Traffic & Travel Time
Smarter commutes. Smoother days.
Wondering how long your journey will take before you leave? TomTom Traffic & Travel Time brings traffic information for your regular routes into Homey, so you can check your commute and use the results in your Flows.
Whether you are travelling to work, heading home or planning another regular journey, the app uses TomTom data to calculate travel times and show traffic information for your route.
Available for testing
The app is currently available as a TEST version. Feedback, bug reports and suggestions are welcome in this topic.
TomTom Traffic & Travel Time | Homey (test version)
Features
- Travel time and traffic delay for your configured routes.
- Route distance, estimated arrival time and traffic summary.
- Route incidents and optional additional incident descriptions when available.
- Route map image with start and destination markers.
- Scheduled monitoring, with configurable days, time window and update interval.
- Route preferences, including fastest, shortest and eco/efficient routing, with options to avoid toll roads, motorways and ferries.
- Alternative routes in Advanced Flow, when returned by TomTom.
- Insights for travel time, traffic delay and distance.
- Homey Flow cards for route updates, incidents, thresholds and traffic information.
- TomTom API usage device to help you monitor this app’s requests and configured local budgets.
Routes are directional. For example, you can create separate route devices for Home → Work and Work → Home, each with its own monitoring schedule.
Requirements
- A compatible Homey running Homey software 12.9.0 or newer.
- A TomTom Developer account and your own API key.
- Internet access for requests to TomTom.
The app uses TomTom Routing, Geocoding, Places Search and Traffic services. The route map image also uses the Map Display API. Make sure the services you intend to use are available for your API key.
TomTom’s usage limits, pricing and terms depend on your account and plan. Please check them in your TomTom Developer account. The app’s local usage counters cover requests made by this app; they do not include requests made by other applications using the same key.
Getting started
- Install the app
- Create a TomTom Developer account and obtain an API key from the TomTom Developer Portal.
- Open the app settings in Homey and enter your API key.
- Add a Route device in Homey.
- Search for and confirm your starting point and destination, then test and save the route.
- Open the route device settings to configure your preferred route options and monitoring schedule.
- Enable scheduled monitoring when you are ready. Monitoring starts disabled.
- Optionally, add the TomTom API usage device to monitor this app’s requests and local budgets.
To use route map images, make sure your key has access to the Map Display API and check the Show route map setting on the route device.
Route maps and alternatives
The route device can show a map image of the primary route. The image is generated after a route refresh and updated when the route path changes. Viewing an existing image does not make an additional API request. Images are regenerated after an app restart.
You can request up to five alternative routes. TomTom may return fewer alternatives or none, depending on the journey. Alternative route results are available in Advanced Flow; the route device continues to display information for the primary route.
The electric vehicle option is a basic routing preference. It does not plan charging stops or calculate battery range.
Flow examples
Use the app’s Flow cards to build automations such as:
- Send a notification when your commute time or traffic delay crosses a chosen threshold.
- Notify you when an incident on your route changes.
- Read the current route information or incidents in an Advanced Flow.
- Calculate a route between locations or saved locations.
- Refresh a route or enable and disable its monitoring from a Flow.
- Check whether route data is fresh, whether monitoring is enabled, or whether a route has a matching incident.
For example:
WHEN the travel time for Home → Work crosses your chosen threshold
THEN send a notification with the current travel time and traffic summary.
Traffic information depends on TomTom’s coverage and the data available at the time of the request. A lack of reported incidents does not guarantee that a route is clear.
Support and feedback
Please use this topic for questions, suggestions and support.
When reporting a problem, please include:
- The app version and your Homey model and software version.
- What you expected to happen and what happened instead.
- The relevant Flow card or route settings, if applicable.
- A diagnostic report ID, if requested.
Please communicate application bugs and debug logs in English only. I do not respond to debug logs written in other languages. Please use this dedicated thread for support questions. Thank you for your understanding.
Please do not post your TomTom API key, private addresses or other sensitive information in this public topic.
You can also report reproducible bugs on GitHub.
Support the development
Community apps and appreciation
These Homey Community apps are developed and maintained in my spare time.
Did you know? In my experience maintaining community Homey apps, only a very small proportion of users choose to support their development financially—even when a new device integration or specific feature has been implemented at their request.
Contributions are never required, but they are a meaningful way to recognise the time invested in development, testing, compatibility updates and ongoing user support. If one of my apps has been useful to you, you can optionally show your appreciation here:
Send an optional thank-you via PayPal
A contribution does not unlock additional features or affect the support you receive. It is simply a way to say thank you.
My Homey apps
![]() Smart Presence Wi-Fi presence detection |
![]() Xiaomi Mi Home Xiaomi Mi Home devices |
![]() Broadlink IR, RF and smart devices |
![]() TP-Link KASA LAN Local Kasa control |
![]() Yeelights LAN Local Yeelight control |
![]() Xiaomi Miija Temperature and humidity sensors |
![]() Octoprint Monitor your 3D printer |
![]() Virtual Radar ADS-B aircraft tracking |
![]() enigma2 Control Enigma2 receivers |
