Hi Martijn,
If you have nothing to do and are bored.
Maybe you can find new ideas here.
@Friedhofsblond no thanks I’m good ![]()
Hello Martijn,
I already tried to to disable and re-enable WOL, but stil my NAS stays off.
Any ideas?
I have a Homey pro 2023.
A Synology NAS DS414J.
Synology app 1.10.6
Homey version 12.2.1
Thanks in advance.
Hugo
@Hugo are homey and your NAS on the same Network?
Does WOL work if you run it from another device? Try to install a app on your phone for example
@martijnpoppen Are you sure you meant, IP?
Yes, they are on the same network.
I will check if WOL works in another way.
Martijn,
I checked, I can wake-up my Synology by ‘WakeOnLanGui’ from Depicus.
But Homey does not wake my Synology.
@Hugo please send a report.
and is the macaddress correct in the device settings? ![]()
I saw there was no mac address filled.
So, will check tomorrow.
If it’s not the solution i’ll send you the log.
Thanks in advance.
Edit: That was tgd problem.
My mac-address was gone.
Now it works.
Again, thanks.
When I checked my Synology NAS today I saw that the last update was 2 months ago. Since editing the password didn’t help I removed the device so I could add it again. Unfortunatly when I try to login on my Synology NAS I get the following error: Something went wrong. Check your login and 2FA (optional). I know these credentials are correct. Tried it with another account as well, which gives the same error.
Here is my diagnostic report:
5c4f908d-164c-4901-9a0c-4c18098ae2f5
If you need any more information, I’ll gladly help :).
@daniel3 are Homey and synology in the same network? Seems like Homey can’t reach 192.168.3.10
They should be ;). So I checked it again and they are on the same network.
@daniel3 can you restart the app. Try to pair again. Send a new report
Hereby the new report: 2f4aa987-786f-4d47-bbc9-d1b1aab83b0c
I already found out that if I disable 2FA for the account, I can login witout issues. It’s only when 2FA is on that I get the error message.
Found the culprit: apperently you need to turn on “Allow users on web browsers to skip 2-factor authentication by trusting devices” withing DSM → Security → Login Settings. If I turn this function on I can login even when I use 2FA.
@daniel3 Nice that you already found that, that was indeed a direction i was aiming to to check ![]()
Bit of a strange problem here:
My NAS and Homey Pro are located in different VLANs, but traffic has been fully enabled between those two devices, with no restrictions for the moment.
The Synology is a DS415+ running DSM 7.1.1-42962 Update 7.
When I try to add the device to Homey it works fine using the admin account. However, for obvious security reasons I want to avoid this.
So I created a separate User account, no MFA and Allow permissions for DSM. But this doesn’t seem to work unfortunately… Also enabling MFA didn’t resolve the issue.
Any ideas?
Report: f30319f0-ad09-4cdc-addf-1af433e30856
@Kimbo yes. You already said that yourself. It works with a admin account. And that’s the requirement to use synology via a API
Thanks for the quick response! Hmm ok understood.
I used an user account because it was mentioned in an earlier post from you: [APP][Pro] Synology - #12 by martijnpoppen but I guess the API has been changed since?
Any tips on making it a bit safer to use the admin account together with the Synology app?
@Kimbo thats for DSM 6
No this is what it is. If there was a other way I would have said that immediately right ![]()
