[APP][Pro] Synology Surveillance Station 2
@Patrick_Leliveld please check the link I shared in the previous post. Looks like that’s the issue you’re facing
I also added that to the FAQ Q3
The user “homey” already had admin rights and rights in synology see screenshots
@Patrick_Leliveld is this inside synology or inside synology surveillance station?
Yes in Synology and surveillance station see screenshot
@Patrick_Leliveld can you:
  1. restart the app (in homey)
  2. Try to login once again
  3. Send a new report
restarted the Synology Surveillance Station 2 app and tried to log in and it failed.
log; e5543538-2978-45f9-b80a-ec1ecb21f202
@Patrick_Leliveld I see a error indicating there’s something wrong with your MFA/2FA
After my Homey Pro 2023 was updated to version 12.0.1, my camera no longer works through the Synology Surveillance Station 2 app.
I get error messages like “Missing Capability Listener: enabled” and "
Missing Capability Listener: button.repair_action_rules" when I try to edit the camera.
I have tried to remove the camera and add it again, repair the camera, restart both the app and the Homey several times but nothing helps.
I have not tried to reinstall the app.
Does anyone else have this issue with the new Homey version?
@SThyni didnt hear anything yet. But please send a diagnostic report
Done, c29f73ac-917e-49f3-a548-21c0d50752b0
@SThyni please check FAQ Q3 [APP][Pro] Synology Surveillance Station 2 - #4 by martijnpoppen
That’s weird, I haven’t edited the user since I created it. But now it had All-Object Manager rights, when I changed to Administrator it works fine again.
Thanks a lot for your quick help!
Hi
As the connection homey / surveillance station is periodically lost (no explanation why !), I have to repair the device Surveillance Station by inserting my credential.
Could you tell me if it is possible to have a script in Homey pro to reconnect automatically to Surveillance station ?
if yes, how to proceed ?
Thanks,
@Jerome_Lechatreux Please send a diagnostic report when this occurs again.
This should not happen and the connection should be kept alive
Do you use 2fa?
@Bulletcather no I don’t use 2fa
@martijnpoppen I did a diagnostic report 0C1A7A03 now,
but I’m not sure it will be useful because now the device is reconnected.
I have a lost connection after every restart of Homey. Maybe thats your explanation too.
@Jerome_Lechatreux That’s a Report for Athom employees i can’t use that. But please send a report when the issue occurs, otherwise i can only tell you that everything looks good :wink:
How-to send a diagnostic report:
  1. Via Homey Mobile app:
More - apps - Synology Suveillance Station 2 - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
  1. Via Homey Webapp
Settings wheel bottom left - Select Synology Suveillance Station 2 - Click on send diagnostic report
@martijnpoppen find the diagnostic report b3faee63-eb40-4e5f-93e9-e0267b447a81
