[APP][Pro] SONOFF Zigbee
Same here.
After restarting it takes a bit more then 1 minute to get the timeout message.
But not all devices (SNZB-02D) are affected, only 3 or 4 of 5. And always different ones after restarting the app.
Same here. Reboot : NOK, and i try restore before the update, NOK too
I’m having the same problems after updating to V0.0.25 at 9:32 today.
The temperature sensors SNZB-02D and SNZB-02 no longer remain online.
The door contacts SNZB-04 do not cause any problems.
Got the same. All temp sensors topped working.
Hi, same for me, all my devices Sonoff SNZB-02P stop to work since this update :frowning: Do we know when this will be solved ?
Same here since this morning for all 3 temp/hum devices SNZB-02D and eWeLink TH01,
restart app, and restart homey does not fix it.
Same on my from today, but as an extra i have some more issues with zigbee network
obraz_2024-01-29_173329793
test version out with potential fix
Thank you Johan! Installed version 0.0.26 and the 8 devices are at least not flaged as unavailable, but the values are not updated and are the same as at the break 6 hours ago.
I hope I don´t need to reconnect my all my SNZB-02D, because it was a game of patience to connect them at all and some took 20 or more attempts.
Thanks for the feedback @AnBo, try power cycle one unit, if it starts reporting we have a working driver. If the other units does not report over time you might need to power cycle all (or push inclussion button to make them re-pair, no need to do a full pair process and should not have issues while).
Please try the new test version.
@Peter_Kalrsson, @Emil_Nojd, @PeterHa, @Dam-Ien, @J_de_Boer, @David_Sundqvist1, @David_Steiner, @Dj_Kolk, @Slawek_Pe
Thank you Johan, everything works fine now, just had to wait a bit and the sensors started after some time (1-2 hours) to delive values (so no need to power cycle one unit). Thanks for the update!
Hello Johan,
After installation of the new app and maybe pushing on the button of one of the temperature sensors (or it was Murphys law) all 3 started sending data.
Many thanks,
Johan de Boer.
All working with my homey now. Thank You @johan_bendz
All works again, thanks for a very quick fix.
Thanks for your swift reply @johan_bendz - very appreciated, installed, works perfectly!
Thank you Johan for the fast fix, everything works fine again.
Looks like the fix works, thnx
with the last update (version 0.0.26) my ZBMINIL2 stopped working even after doing a reset.
Do other have my problem?
Thnaks
My ZBMINIL2 is still fine with 0.0.25. Haven’t updated yet.
