Zigbee device suddenly not responding until you restart Homey? Zigbee Monitor notices it first — and lets a flow fix it.
Zigbee routers are your mains-powered lamps, plugs and relays: they pass on the signals of all your other Zigbee devices. When one of them gets stuck, it often still looks available in Homey, but it no longer reacts — and devices behind it can drop out too. Usually you only notice when a light doesn’t turn on… and the fix is restarting the app or Homey.
What it does
- Tests every router actively — every few minutes (default 10) it gives each router its current state again (on/off or dim). Nothing changes, but the command really travels over Zigbee, so a router that stopped responding is noticed right away
- No false alarms from a single hiccup — one failure is re-tested after a minute; only several failures in a row count as does not respond
- Works with routers of any app — Philips Hue without bridge, IKEA Home smart, Aqara & Xiaomi, Tuya, SONOFF, Innr and more. Homey marks mains-powered Zigbee devices as routers; Zigbee Monitor finds them automatically
- Notifications when a router stops and starts responding again, and a log of all events in the app settings
- One overview device with a red dot when a router does not respond
- Flow cards — [router] does not respond · A router of [app] does not respond · [router] responds again · [router] responds (tests right away) · A router of [app] still does not respond · Zigbee Monitor is running longer than [minutes] minutes · Test [router] / the routers of [app] / all routers now
Repair it automatically with a flow
Apps can’t restart other apps or Homey themselves, but a flow can with Homey’s own cards. Example Advanced Flow (one lane per app):
WHEN A router of [Philips Hue] does not respond
THEN Restart app [Philips Hue] → wait 30 seconds
AND A router of [Philips Hue] still does not respond
AND Zigbee Monitor is running longer than 60 minutes (prevents a restart loop)
THEN Notification + Restart Homey
ELSE Notification "repaired by restarting the app"
On my own Homey it caught three routers (Hue and IKEA) that stopped responding at night — the flow restarted the apps and they were back within 30 seconds, before anyone noticed.
Getting started
- Install the app
- Optional: Settings → Apps → Zigbee Monitor → Configure to choose which routers to monitor, the interval and the notifications
- Add the Zigbee Monitor overview device and build the repair flow above
- Tip: to get notifications as push messages, turn them on in Homey → Settings → Notifications → Zigbee Monitor
Install
Zigbee Monitor in the Homey App Store (test) — feedback is very welcome!
Works on Homey Pro (2023 or later), Homey Pro mini and Homey Self-Hosted Server.
Note: the app uses the Homey Web API permission to find your routers and send them their current state. Most lamps and plugs ignore a command that doesn’t change anything; if a device does react to it, switch off monitoring for that router in the settings. No cloud, everything stays on your Homey.
Links
- Source code: GitHub - sanderjacobsen/zigbeemonitor
- Buy me a coffee: https://ko-fi.com/sanderjacobsen
Questions, ideas or bugs? Just reply in this topic. ![]()
