That’s how it should look like (the cover image needs ~5-15 seconds to load):
Update to Version 1.3.2
Camera, Energy and Thermostat modals redesigned as centered cards matching the speaker style; 7-day energy chart: outlier filter removes initialization artifacts (inflated kWh values); ‘Show all flows’ profile option fixed; device type shown in profile device list
Update to Version 1.3.3
Performance: RAF fallback for older WebViews; icon cache size limit (200 entries); single XHR for icons (no double-fetch); parallel Insights queries with concurrency limit (max 4); CSS contain on device tiles; static file cache with mtime invalidation; JS/CSS served with ETag + no-cache for instant freshness after updates; zones cache TTL 30 min; search field in profile device list; sticky Save button in profile editor
On the homey it says Discharging and the arrow on everything is going in the correct direction. It’s not a big issue because the information is all correct. But the battery says charging when it’s actually discharge to the house on the shelly app.
I’ll find out tonight
Iv tested the new update and it works perfectly now once iv inverted the settings. Amazing! ![]()
Witch displays are compatible?
Tested on normal (older) Shelly Wall Displays and based on the Feedback as well the bigger ones: Question for anyone using a Shelly Wall Display (XL or X2i) - #5 by Steffen_Schmitt
Is there a way to increase the refresh rate or update cycles or what ever it’s called on the dashboard?
If I turn something on using a button it takes a very long time for the dashboard to update the input to reflect if the light is on or off.
Please install 1.3.6 and let me know if it fixes the issue - Thank you!
Hey mate, I’ll have a play with it for a day or so and get back to you but atm it works like a dream. This app is getting better and better.
Would it be possible to get camera Feeds to work?
Right now still images from cameras work where the device type is camera (at least for me using Ring devices).
What type of camera do you use?
Are you able to see the images here?
Yes, I can open up the camera URL on the developer tool and play my Camera.
Update to 1.3.7
Check if it works now
If not: Open http://<homey-ip>:7575/api/debug/images — check if the camera has a non-empty images array
Please post result here or send me a PM
I don’t know how to PM sorry. That link you sent me
I don’t know how to make it work. PM me if you want
My Camera works on Homey in its integrated dashboard using the cameras URL IP and password.
You are able to open that link and you see the camera mages?
Should look like this:
Replace {homey-ip} with the IP address of you Homey. Open the URL and send me a PM (personal message). ![]()
URL: http://{homey-ip}:7575/api/debug/images
Should look like:
Thank you
