Hi. Yes this status changes.
If the status does change there, then I don’t really understand why the other one doesn’t change. It uses those values to determine the Wi-Fi and tank status.
If you remove the tank, do you get something like warning_tank_missing?
Have you happened to come across anything else about this, @Denn1s while improving the code.
Looks like the “missing” signal is coming and the"full" warning too now. Looks good now. Thanks for the app!
Does anyone know if Quatt has plans to open-up a bit? I would very much like to decide myself when the heat battery will start charging, as now it is right after a shower but I might prefer to wait a bit until the prices are lower; if there is still enough hot water left, then why worry…
You need to indicate in the Quatt app that you have a dynamic energy tariff. You can then influence when it charges by setting the times during which it is not allowed to charge.
Thanks for the suggestion. Good idea but it is not exactly the way I would like this to implement. I have this, and outside the non-allowed loading hours it takes its own plan…
Maybe openquatt
Would love to see OpenQuatt for full-electric, currently only for hybrid… And from the comments I doubt if they ever will make it work on full-electric, probably the developer just has the hybrid…
i am thinking of going all electric.
But i am wondering will there be an option to control the heatbattery?
Not at this moment.
