[APP][Pro] Pushover
Got your dono! Let me know if you are pleased with the feature.
It works well thank you. Is there any chance you could also add a flow card with both an image and a url? Then I can send a snapshot from my security camera along with a deep link to my NVR app to show its live feed.
Thanks again for your quick responses.
New version submitted. TY for the dono.
New test version working beautifully, thank you again
@Kim_Kokholm sorry to bother you again but could you possibly add Priority to the two cards with URL and URL Title? I am using these for doorbell notifications and I want to be able to control the priority of the notification depending on whether I am home / asleep etc.
I guess maybe that could be made an optional field to avoid that being a breaking change for anyone else with these cards in their flows.
Thank you again!
Hi @Jonathan_Draper
As I am aware, optional parameters does not exists. I’ve added a combination with url, image and priority - hoping to save your day :slight_smile:
TEST version can be installed from here:
Oh fantastic. Thank you so much!
Purely for interest since the new card will be all I need (thanks again), there is a section showing how to add optional arguments on a card here: https://apps.developer.homey.app/the-basics/flow/arguments
Hello Kim,
Thanks for the quick reply on qithub :slight_smile: I just read the topic. Is it correct that it is to difficult to setup the extra values what comes with the extra emergency option? Or do I read it wrong?
Hi @M_J
Homey would like to keep the cards simple and not too complicated - I also think this is what most of the users would like as well.
Last time I’ve read the api, the values for emergency is kinda tricky - maybe they’ve solved it on their test-page. What I’ve experienced is some rules for repeat and pause, some threshhold values are allowed - so what I would like to implement (cannot remember if I’ve already have) is for someone experienced user with Pushover to tell what is the optimal options for Emergency - I can then in the app add Emergency 1 or 2 - this specific ā€œgoodā€ values = bringing the complexity down for what values are allowed and so on for the emergency option.
Does this sound ok?
That sound great. I think this is a nice future for the app :+1:
Hi @M_J
I would love to implement emergency.
I do need some feedback.
I do need some valid values for entry and expire. Please see the documentation.
https://pushover.net/api#priority
I do not want every usage to set the entry and expire - I want to adopt Emergency with entry and expire preset - and not settable by the app/user.
If you provide me with valid (please, well-thought) values for entry and expire, I would love to implement these for the Pushover app for Homey.
Thanks for the effort, and ofcourse i could help you (in the way i can).
I think it’s a good solution to set some static values, so it’s just a priority change for the user.
First a possible list of situations where users used the emergency prio:
  • maybe as a sleep wake up call for important messages
  • when people don’t react on notifications, so they get a emergency reminder that the notification is important
  • for fire or water alarms.
If i take the possible situations as a guideline than i think dat the retry values don’t be the low.
The smallest value of 30 seconds is to low i think. Users find it to annoying.
Maybe 5 minutes (300seconds) is a better choice.
For wake up situations it’s not to often i think. (users have also some time to acknowledge the notification).
What i don’t know is how the acknowledged input works. Is this for example when a fire alarm gets disabled or when a flow gets disabled in homey, or how does this work?
For the expire parameter it’s a harder solution. In my situation i would suggest 20 minutes, so you get 4 times a new reminder. I also think that it isn’t desirable to use the max expire time.
What are your thoughts about it?
Hi @M_J
I’ve now added Emergency as you have ordered. Please check this out.
I’ve also added RateLimit
Thank you!
I quickly tested it and i get a notification in emergency prio. But only ones and without a sound?
I will check if i could find the problem.
Hi @M_J
Just to be clear, does emergency work as intended? Please let me know if I’ve missed something.
Yes i found the problem. It works great! Thank you :slight_smile:
Hi Kim,
Thx for making the pushover app. Is there a possiblity to change the retry interval and Emergency Retry Expiration with an emergency prio message? Like 30 seconds? instead of 300 seconds?
Hi @snowboardrulez, thank you for your reply. I’m back from vacation.
Retry should be 5 second and expire after 20 seconds - giving ~4 ā€œpingsā€. Do you experience something else?
Please refer to the docs:
I have asked for usable settings for these settings - as I dont want to add extra complexity to the user-interface and are looking for valid default values for emergency-usage.
Hi Kim thanks for your response, I understand that you don’t want to add extra parameters.
I noticed it because I apparently used the other (older) version of the pushover app.
My experience is that with an emergency priority notification (2) there are 300 seconds (5 min) between the first and the second notification. It seems that the retry parameter works or can be defined.
Perhaps 1 or 2 fields should be added here. The Retry and Expire values
Emergency Priority (2)
*The retry parameter specifies how often (in seconds) the Pushover servers will send the same notification to the user. In a situation where your user might be in a noisy environment or sleeping, retrying the notification (with sound and vibration) will help get his or her attention. This parameter must have a value of at least 30 seconds between retries.*
*For example, sending a retry parameter of 60 and an expire parameter of 1800 will cause your notification to be retried every 60 seconds for 30 minutes. A retry parameter of 30 and an expire parameter of 10800 will retry every 30 seconds up to 25 minutes due to the cap of 50 retries.*
