Hello Gruijter,
i am using this one.
Can you post the price Insights of the day when it triggered multiple times? The price image you posted before does not have any negative prices before 8 o’clock.
I thought you just wanted to see which card i use, so the flow i posted is not the one that failed on me when the prices was negative for several hours (Price image posted). This one is the one that failed :
I do not have a screenshot of Price insight for 16.07.2023. I just took a screenshot of the price image. But negative prices will happen again, so i can provide more information then.
Ok, will look into it. That flow indeed should only trigger once. Thx for reporting.
I did not notice any problems. The bug with the double message seems to be removed :+1:
Question: with a flow you can change the energy tariff(this is group 1).This works fine. But i tried to change the energy tariff for my solar panels, which doesn’t work. I changed the group for the Solar Panels into 2 and made a flow to change this(set energy tariff for group 2 to ……) But nothing happens.
Any ideas?
Are you sure you use a valid price (= a number)? I.e.not a text or using a comma when you should use decimal point (or vice versa)
I copy/pasted the THEN part, so i suppose this should be right.
Mmh. Ok, could be a bug then if it does work for tariff group 1.
Also tried it for group 3, doesn’t work either
I have an Aurum EnergyFlip P1 meter and would like to connect this with PBTH.
When adding a new Power Summarize device I can’t select the EnergyFlip.
Does anybody know if there is an option to add EnergyFlip to PBTH?
I do see a device called HOMEY_ENERGY_SMART_METERS, can someone help me to understand what this device is about and what energy values are collected in this device?
I could probably add native support in a next release.
I need to know from you the capability names. Please go to Homey Developer Tools
And select your P1 device. Create a screen shot of the capabilities, similar to this one:
Or you could already use that if EnergyFlip integrated Homey power correctly. Native support is better though.
Hello Gruijter,
Thank you for the quick reply, however there is no Homey app yet for the EnergyFlip, hence I do not have such a table in the Homey Developer Tools. I hoped that the HOMEY_ENERGY_SMART_METERS would be a way to connect to the EnergyFlip eventhough there is no app for this yet.
Ah, well that explains it :rofl:
You can tell them I can make a Homey app for them.
v5.6.9 is released as test: Power by the Hour App for Homey | Homey
  • DAP: Fix trigger flow for new prices.
  • Added THEN flow card to get prices JSON (advanced Flows only)
This should fix the issue: The card "New prices for today/tomorrow" is not triggered · Issue #133 · gruijter/com.gruijter.powerhour · GitHub
Thanks @Gruijter :slight_smile:
Will upgrade, test & reply :crossed_fingers:
Should this resolve the issue with consecutive hours, with negative pricing?
Regards
Marius
Dont think so. The code changes probably dont affect that.
Ok.
Regards
Marius
Thanks a lot for the new version. I can confirm that the trigger for new prices for tomorrow works again! I just got a notification that if I delay charging my car, I can save €0,79 :blush:
