Hi - I love the app and have been using it from my start of Homey (switched from years of HA usage).
Recently I setup an automated EnergyLogger flow to a google sheet. I automatically log energy usage every hour. When adding up all hours of the day, I get a different result than a full day total. The full day total lines up with my P1 HomeWizard reading. From this I deduce that there is something wrong (or I am doing something wrong) with the hour results. Can you share your insights?
E.g. for gas:
m3 deze dag: 8.56
sum of m3 dit uur: 7.431
P1 reading: 8.560
Similar results for power (stroom) and water
Thanks!
This hour is still counting. Try adding all ‘last hours’. Because that has finished counting.
Hmm… true, I will change that later today. However it wouldn’t explain that the individual sum would be higher. If the hour is still running then I would expect the total to be (slightly) lower
For whoever is interested, I’ve created a short tutorial on how to display the current energy price using the Power by the Hour app and DataVista. If you’re curious about visualizing hourly energy prices with a gauge, check it out here:
Very nice, Erik, thanks!
One thingy about
  1. Do not overwrite the label, unless you prefer to display a fixed value instead of the actual price.
In case I want to use the Better Logic currency formatter (good hint!), it’s output tag can’t be used as [value], because it returns a string tag.
So I use it as [label], and the original numeric price tag as [value].
It updates every hour @ price change w/o problem:
New to PBTH and have a few questions. I am in Australia and my energy provider sells at wholesale prices. They also have a Buy Price and a Sell Price, both of which can be -ve or +ve.
Trying to understand Update Group. From what I read you just enter 1,2,3 etc and track manually what you want to use each group for, although I’m sure I could parameterise them.
So is it valid that to track the buy and sell prices I can enter 1 for the Sell price update group and 2 for the buy price?
Also is there any issue with these values being -ve?
Thanks for pointing that out @Peter_Kawa! I’ll update the tutorial and maybe update the DataVista app. To not clutter this thread, lets use the DataVista topic for further discussion.
Is the gas price from anwb where offline? Al 2 days the same price?
That’s what ANWB also says
So i see no problems
That is not the ANWB gas price.
Also the gas price of Frank Energie is wrong with €0,79 for today.**
Zonneplan is asking €1,33**
Edit
That are the graphics here
It is.
Oops.
This is with more info.
Partly due to the low prices looked more E prices.
very nice APP, I already found many nice cards to use, but is there a possibility to get the price in Swedish öre instead of SEK? (100 öre = 1 SEK). The prices are often low, so low that the resolution in SEK is not showing the actual price.
In settings you can change the number of decimals.
That will not help me much, only more zeroes. I wish to have it in öre
Just adjust markups (% and fixed) to result in 100-fold numbers. And change the SEK to ORE.
Is it all so posible to make one tag more to use
Price -1hour
so you can use it on export data to a sheet (google) on every hour (at electricty) and in the first hour off the day to export your gas price . And yes we have all ready Use last hour and price last hour.
Ok i can calculate back in the sheet, but if avaible i can export direct.
Now I have a flow with a variable for the price (Electricty/gas) last hour/day
every 5 min after the hour (for Electricty)
Copy the info to a new row in the sheet #date;#Time;#Price-E-1U (the variable);#money lasthour
Then I copy the #price now to the variable #price-E-1U
It do’s the same but it some extra task/work :slight_smile:
there all all ready a lot off tags for ever + houre in Electicity and gas so maybe one more for the latest hour -1 could be one more.
Beste wishes for 2025.
There information.
For Zonneplan E, I have found out that 0,14285 is the Fixed markup.
Best wishes to you all!
When doing the yearly changes in the app I found out that the TTF_LEBA_EasyEnergy has not been updated for weeks. Is something wrong? :thinking:
Because I was switching to Zonneplan I noticed it 11 days ago. (Post 2719)
Now I have take TTF_EGSI.
