Yeah, but I’m not sure adding this will make sense, will it?
Auto is the most expensive, so trying to keep that to a minimum. I have 2 ACs, one on each floor. During daytime I don’t want auto on second floor as it is more expensive and we’re less there. This time of year it’s very hot outside before midnight, need cooling, but then temp drops massively. So I’ve set it to auto for the night.
Besides I imagine if wanting to use the away mode, auto is the most stupid setting. Unlike a normal oven, the AC will start cooling to reach the away temperature, which is a waste. So if I’m on auto, I would have to use another app to change the setting. And away mode could be auto triggered or manually set.
Zone parameter
Probably a good idea. I hope you mean zones created in the Homey app, and not new zones in your app?
Heatit
TRM3? I plan to install 3 of these. Thanks for the heads up.
Price tab
I guess what’s confusing is having to go to the price tab to handle on/off, when price is not a concern for me at this point. But I think I grasp how it works now. Maybe some text inside the “information buttons” would suffice.
You are also implying I have to stop using my existing schedules and use your schedule app for day/night in order for “on/off only” to work in this version. “Vacation mode” is also missing btw. I reckon “away” is meant for when at work. “Egen” can be used…But then you lose that extra mode which could be nice to have in spare.
My suggestion is to add a whole new mode of operation above all you have right now. “Power on/off mode” let the user control on/off and not mess with temperatures, day/night etc… “Power, price and heating mode” for the one you already have?
Then we can have it both ways?
My stomach tells me I will eventually switch to the fully controlled mode you “preach” and laid ground for later…But for starters I’d really like for your app to just cut power, let me see that it works, then decide later on if I want to switch to the “Tibber competitor and then some”.
If HeatIt is the only reason why this expanded so much to begin with. Could we reach out to HeatIt for a firmware upgrade or the likes? Hack it and fix it that way?
Car charger
Yeah I could help out testing. But as you might have figured, I’d try out option 2, on/off.
Can’t find my Easee charger inside your app though. For this I use flow cards?
Could adding support for Easee and Zaptec, the most used smart car chargers, to show up inside the app be a future update?
