My remote is draining battery fast, used to hold over a year?
Now if indeed the battery reports is actually the issue I can do without it…
Hi, what model is it?
RWL000, RWL022, other?
It’s a RWL022.
Philips Hue, without the bridge – v2.3.2 (Test)
A new Test version is ready, focusing on an issue that has caused unexpected app crashes for some users.
What’s fixed?
I’ve identified a potential cause of the Invalid Driver ID errors reported in recent versions.
Some of the Flow cards allowed devices belonging to other Homey apps to be selected. Under certain circumstances, Homey could then attempt to resolve those devices as Philips Hue devices, resulting in errors such as:
Invalid Driver ID: bulb -
Invalid Driver ID: motionsensor -
Invalid Driver ID: tunable_white_bulb -
Invalid Driver ID: motion.ac02
In v2.3.2, I’ve updated 11 Flow cards to limit device selection to supported devices belonging to this app.
What I’d like you to test
If you use our advanced Flow cards for dimming, lighting effects, color temperature, sensor suppression, or temperature and luminance conditions, please check that your existing Flows still work as expected.
This update doesn’t change Zigbee communication, pairing, polling, or device behavior.
A note on remaining errors
I’m still investigating a separate group of Driver Not Initialized errors. This update may resolve one important source of crashes, but I don’t yet know whether it addresses every related issue.
As always, feedback is very welcome, particularly if you encounter problems with existing Flows or see further driver-related errors.
Please report any findings here or on GitHub.
Thanks for helping make the app better!
I used cards for dimming my ledstrips Flux (selecting a device, increasing/decreasing brightness, number of steps) in advanced flows, and it worked perfectly. However, since version 2.3.2, these are no longer available ![]()
Hi @Johan_Hindryckx, thanks for the feedback!
I made a change in the latest Test version (2.3.2) that unintentionally affects some existing Flow cards. I’ll release an updated Test version to fix this.
Going forward, new Flows will use the device-specific cards you now see in 2.3.2, while existing Flows using the older cards will continue to work without any changes.
All the functionality you’re used to is still available. You’ll now find those Flow cards under each individual device instead of under the app.
Thanks again for reporting this!
I wanted to buy the Dymera lamp, but if I look at devices in Homey there is only the Dymera bottom part?
Hi, I’m currently setting up my entire home lighting again from scratch haha.
I have about 8 motion sensors and 10 remotes around my house to add into homey, as well as a play gradient lightstrip (paired with govee, ugh lol). SO happy I stumbled back here as I went to set up, thanks so much for all your work and I’ll be there!
See you in git <3
