Also Firmware version1.9.0+1+WL-1
I have exactly the same problem. I have a peblar business with the latest firmware. And a homey pro 2019.
Hi Tnx for the app. I have many times in the app there is a problem, there is no problem. And the Peblar can not start with the card of the company. So i remove the app and the Peblar can start with the company card
Hi @evdpol !
Thank you for this app, overall it seems to work very great.
But I have an issue since the newest update (and two follow up questions):
Since the new update I seem to have a problem:
Every minute or so the charger becomes “not available” with this error (see image), and then it seems to repair itself after a couple of seconds. This happens frequent enough that it messes with my flows (it causes errors when a flow triggers and the charger is not available).
Any idea what’s wrong? If you need more info from me, let me know how I can help!
My current Peblar firmware is 1.8.1+1+WL-1 if that helps.
In the Homey app the max limit I can set for the charger is 16A, but my charger actually goes up to 32A:
On the other hand setting the actual limit does work trough the Homey app! So it’s not completely broken or something, but it would be nice to be able to set the total capacity of the charger? Any way I can set or change this limit correctly?
Thanks for your help!
Which version of the app are you using?
Is it the latest?
Can you remove the device, and add it again? Does the problem then persist?
Ok, weird, but removing and adding the device again seems to have fixed it.
Also, the charging limit issue is now fixed, it shows the correct 32A range (instead of 16A)!
Did I select the wrong device or something? I was not sure if I had the Home or the Home Plus, maybe I picked the wrong one before?
Anyway, I’ll let you know if it starts acting up again
Thanks for the speedy help @evdpol !!!
I’m looking into the Peblar as my next EV charger. I can’t seem to find the correct flow card trigger “IF EV is connected”. I don’t want to use any RFID-card, just plug it in and let Homey take care of the charging. Is it possible to add the flow card “EV connected” and “EV disconnected”?
The use case is to let Homey know the car is connected, so Homey can fetch the latest battery status.
Same problem here when trying to change the charge mode for the Peblar business. Error not_setable.
This should be fixed in the new version of the app (1.0.4).
Thanks!
In the app itself I can slide the current bar from 6 to 32 amps. But when i try to make a flow to set the current to 32 amps the bar for the current tag is limited to 16 amps. Could you please fix that.
Thanks!
2 screenshots of the issue with the Peblar business. One is the app and two is the flow tag.
I use the Peblar business version
Anyone? Does Homey know whether there is a car connected or not?
Has anyone figured out how to control the LED brightness on a Peblar charger using Homey Pro 2023?
The percentage-based dimming settings in Homey don’t seem to work correctly. I’ve tried setting different dim levels, but the LED brightness either doesn’t change or doesn’t respond as expected.
Has anyone found a working solution?
It’s supported in the other Peblar app [APP][Pro] Peblar EV Charger - Plug in. Power up. Automate
My Peblar charger no longer seems to send kWh and W data to Homey Pro (2023).
In addition, the energy flow animation in the Homey Energy page (app on iPhone) no longer shows power going to the car, even though the car is actually charging.
Has anyone else experienced this behaviour, and is there a known fix or workaround?
What could be causing this loss of data integration?
