Ah, I see. I assumed you automated the restarts for some reason.
Nope it’s just how our wifi is, no one knows why.
@John_William_Brekke and can you share your flow aswell?
@John_William_Brekke notifications do not work when the internet is down ![]()
Oh, so i can do lights and devices only then?
Everything which is available locally yes
Ohhhh, my bad ![]()
You can use timeline notifications and/or Simple Log cards in that flow to record lost internet connections. These do not need a network.
Add such a flow with “Internet connection restored” card, and you know the downtime as well.
And, then you can send a push notification along with it, like, “internet connection was down and has been restored” ![]()
Can you maybe please provide the values as number or Boolean(s) so they now can be used with the new duration functionality. Like internet connected/online :Yes/No or True/false.
So we can now set When Internet Connected is false for 5 minutes then …
Or
When Internet connected is True for 7 minutes then ….
I Just want to trigger a flow only after 9 minutes of internet loss so its not triggered by an automatic firmware update of the modem or router.
Thank you.
@DoctorBazinga sorry this is new to me. Can you specify what you mean?
Its the new Homey Pro firmware capability/functionality ![]()
SysInternals app provides its Lan/Wifi “Connected” state as a boolean (Yes/No) value so we can use it as trigger in the newest “duration” trigger in flows.
Because you can add the LAN/Wifi connection as a specific additional/virtual device and read its parameters/values.
(You could add to such a virtual device also values like “Last time internet disconnected” and “last disconnected duration (in seconds)” & “Time since last disconnected(in minutes (integers value)) ” and “Time since last disconnected (in minutes (integer value))” etc . (See the request/post of Peter_Kawa on 5th of may )
Some people That have stability problems could make good use of the values/information . For example by using it as a trigger to restart homey after/before reaching a specific value ![]()
So people can use this values in flows and compare them.
Something like that maybe for the internet connection of the homey ?? ![]()
An internet Connected (Yes/No) value would be very interesting.
Thank you very much. ![]()
@DoctorBazinga got you, not sure if I can manage this. As it is based on a device (capability). And network check has no devices to add. So i don’t think this is possible, but let me check that ![]()
The value/fact/trigger that your network app “internet connected” and “internet disconnected” somehow at least has to be an internal Boolean (in the code) anyway. Or am I mistaken? So providing a fictional/virtual device (that can be added/“installed” like sysinternals app does that has these values internet connection:Yes/No , Last Disconnected: Time stamp ,Last connected (Time Stamp), Longest online time (minutes) longest offline time (minutes). Duration of current state (Online or offline (minutes) shouldn’t be magic imho. ![]()
Maybe you could ask @Dijker from SysInternals for help to create this virtual/non existent device that uses the internal values of your network app. ![]()
@DoctorBazinga Oh i’m fully aware how to build a device in Homey. It’s more that it’s overkill for the feature. As that would mean you first need to add a device before you can check your network status.
As said I’ll check what i can do.
To save you from work, Martijn: The Net Scan app by Adrian has the possibility DrBazinga would like.
It indeed uses boolean devices for each unique local or internet IP check.
I already use the Netscan app in that way.
Use them as an “and …” condition in flows to prevent false positives/negatives of a triggered “internet (Dis)Connected” by the network app.
But what about if the internet disconnects inbetween the test/ping time period??
With the value of “ Internet (Dis)connected” available already this will be easier imho.
Shorten the interval and or live with max X seconds internet outage.
I think you shouldn’t ping a web address every second, the other end won’t be amused.
That’s why “Netscan” is not so 100% suitable for an internet (dis)connection detection.
I Ping my DNS servers, my (Ziggo) modem, my (Ziggo) cable network gateway & my internal router (ip). All around different times within 75 -131 seconds.
But I will no know how long my internet is already online or offline precisely due to these longer intervals and also the required failures needed/setup to be offline.
All setup by me for at least 2 failed attempts to ping any ip-adress.
