Network Check Turn on/off noe zigbee on router
Hi
I try to do when then internet connection is lost it turn the switch to the router off and the on again after 1 min but when i test the flow it turn it off even if the internet is ok
The flow says when the internet is lost
And the Plug is turn on the turn off the plug wait 1min turn it on .
When i test the flow it turn off every time
Have i done any thing wrong
Don’t know the network check app that you are using, so can’t really help you with that part, but I’ve created a similar flow for my internet connection. It checks every 5 min if 2 servers can still be reached (i picked DNS servers, but could be any website with a high uptime) and if BOTH are “offline” it’s very likely it’s either my internet provider or my modem, so I reset the modem.
App used for the connectivity check is the Net Scan app.
Thanks
I Will try that and you flow to see if it works and return if it works Thanks for Quick reply
The app i Can see net scan to put in the flow i have installere it ans Can see it in the apps
if you go to your devices, you can add a “device” (I added 2 devices)
In the settings (for example if you want to use the Google DNS server to test, fill out these details
(port 53 is used for DNS, if you want to add a normal website to check it’s mostly 443)
If you need some DNS Servers to check, have a look here. I use Quad9 and Google at the moment, but you can also add more or others
thanks alot to take your time to help me now it works, thanks alot :slight_smile:
for breaking it down for me
i get it to work et stops with the offline bokses and only goes through if online.
i setup the net can app
i also try with 8.8.8.8 also is there a way to test the net scan
