[APP][Pro] Marstek Energy Storage
Is it also possible to set both charge and discharge power limits?
This would help to implement more fine grained control in home automation.
No those are not writable registers unfortunately.
Hi everyone,
I am about to purchase a Marstek Venus E Max (10 kWh), specifically because I want to control it via Homey based on dynamic pricing. Before I order, I want to be sure that this will work.
In the app store, only the Venus E and the Venus D are listed as supported devices for this app. The Venus E Max is not mentioned. Hence my questions:
Does the Venus E driver also work on the Venus E Max, or is it a separate device that is not yet supported?
If so: do the main flow cards work fully on it? I am thinking mainly of ‘Set the target power’ with the Homey setting, and setting the charging and discharging cutoff SOC.
Is there anyone who actually has a Venus E Max running with this app? If so, on which battery firmware, and via Wi-Fi or wired Ethernet?
If the Max is not yet supported: is that on the roadmap, and can I contribute to that in some way (testing, providing logs)? Context of my setup: Homey Pro, three-phase connection, solar panels with their own inverter, and a dynamic contract starting in March. The battery needs to run a cycle daily based on price differences, so reliable control from Homey is not an extra for me, but the core of the business case.
Thanks in advance, and thanks for the work on this app.
Regards,
Rik
Your the first that will try it :grin:.
But I will work with you to make it sorted if the driver first work yet or completely.
I do suggest to use a serial modbus gateway for improved stability. The v3 150 firmware seems to have stability issues.
