I’m using 3 pcs Marstek V3 with homey Pro TCP/modbus. This works fine.
I’m trying to make a flow to load the batteries at night. It seems to work correctly but i can’t get the Modus back to “ normal” mode. Therefor in de “ manual” mode i get the faillure “wijzen”. Can you give me advise if i’m using the commands in the flow are they correctly used.
First, can you check if I used the functions “ optimize modus” and “ gedwongen laadmodus” in the correct order to achieve the goal to “ force” load the battery at night hours. For I’m not sure that iv’e used these functions correctly. (see the thread 241 copied in, screen shot flow homey pro)
Furthermore how to use “ gebruik forceer laadmodus” within optimize modus. vs “ gedwongen mode uit” within gedwongen laadmodus. This is not clear to me.
The main operation mode dictates main behavior. Only if set to force control the modes in the force mode becomes relevant. The off stand in that mode then forces the battery into an idle stand. The other force labeled settings are all about one of those modes.
Switching from force control to any other operation mode should activate that mode, hence ignoring whatever was set in the force mode.
The grid 0 mode is auto load/discharge, other settings are mostly ignored.
Trade mode enables the tariff trade so just like grid 0 it ignores most other settings.
Manual would activate the mode that requires time schedules configured in the battery. I did not add support to manage those time tables.
Still one question, regarding your explanation: I’ve used the following flow using “ optimize modus” AND “ gedwongen laadmodus” is this the correct way or is only ONE of the functions necessary, to achieve the goal “ force-load battery at night-time” : See Flow below.
That is correct, I see my Dutch translations are a bit confusing indeed. But indeed you need to switch that work mode/Optimalisatie mode to force mode first. Then you can select the type of force control.
I am currently experiencing an issue with the API cloud connection for the Marstek Venus. It seems to have stopped updating automatically.
I only receive new data values immediately after restarting the app. After that initial pull, the connection drops or freezes, and the data no longer updates. I have already tried completely reinstalling the app, but it results in the exact same behavior. A few questions for the community and the developer:
Is anyone else experiencing this identical problem right now?
Do we know if there were any recent changes or restrictions made to the API interface on Marstek’s end?
Are there any known workarounds or steps I can take to resolve this?
