[APP][Pro] Magic Home LED
@NoWorldOrder Nice! i’ll add the AK001-ZJ21410 with those settings to the app :slight_smile:
New app update (live: 3.5.0):
Changelog:
  • NEW: add AK001-ZJ21410
TNX! Any idea why just green (button and mixer) is returning a slightly different color? It’s more towards yellow.
Yeah thats the translation from Homey to the device color. Same happen for example with Ikea devices :confused:
Is het mogelijk om meerdere controllers in 1 groep te zetten net als bij de Magif Home app?
If not, you can use the Group app to group them < group > App for Homey | Homey
@Randy_Visser no thats not possible
I just setup the app with my MagicHome Account and have 2 exact same controllers connected. Unfortunately they are not accessible and I was not able to figure out the model number. After some trial and error I was able to figure out AK001-ZJ21004 is working best for one of them. The other one, however, I cannot get to work with neither of the settings. I have tried everything and they are exactly the same controller. Any idea?
@Flyto can you send a diagnostic report
Done
@Flyto did you get any code you should send to me? :stuck_out_tongue:
My mistake, apologies! I am still very new to Homey, it was still sending the report (I was a bit too quick to write done) but it gets interrupted with “rate limited” and won’t send the diagnostic report. SO I know that’s not you to blame and through my research I have learned you cannot to s* without the report so I will come back once I have figured out a solution to that :smiling_face_with_tear: Restarting the Homey did not help.
@Flyto a rate limit takes ca. one hour before you can send it again.
still doesn’t work but I will figure it out somewhere, in the meanwhile HAPPY BIRTHDAY :slight_smile:
thanks a lot for all your help and incredible work!
Thank you!!
Noob here. Got a Magic Home controller, RGB SPI. But cant find the right model to get it working. On the print of the controller its printed: ZJ-BWCE-RGBW (but there is only 4 pins on the controller). Magic Home App works great, same for remote. App needs to be set to GRB to work correct.
Any tip to get Homey app to work correctly? (When I add controller, it shows up as AK001-ZJ2148) Colors are wrong, dim seems to work, same for on/off
@Kerberos Magic Home on Homey only support RGB format. Can you try to set that in the magic home app?
Yeah, but there is still not correct colors. Restarted app, still wrong. If I choose green, there is lights in Blue and green LEDs. Thus more I go against green, the more the blue led light’s up and vice versa…
Do seems like it cant get R/G/B at 255 - there is always a mix of colors… ?
@keberos that’s strange. Never saw that. I would suggest to play around with the settings in the normal magic home app.
Magic home app works perfect, but need to choose GRB not RGB to get it working. So, no problem with app or remote control… Only in Homey…
