Hi all
This is the topic for Lightkeeper. Questions, bug reports and feature requests are all welcome here ![]()
Lightkeeper makes the lights and remotes you already have, a bit smarter, without you building any Flows.
App Store: Lightkeeper | Homey
Test version: Lightkeeper | Homey
Source (MIT): GitHub - thomassidor/lightkeeper · GitHub
Issues: Issues · thomassidor/lightkeeper · GitHub
Still taking shape. This is a 0.x app. An update can change or break a device you have already set up, which may mean running Repair on it or adding it again. Please read the changelog before updating.
What it does
Add it via Devices → Add → Lightkeeper and choose one of five types:
Light Remote: turn a remote, switch or dial you already own into a controller for any lights. Lightkeeper writes and maintains the Flows for you.
Light schedule: lights on and off at set times on chosen weekdays, with a colour and brightness if you want.
Circadian light: warmth through morning, midday and evening, following your own sunrise and sunset.
Colour Curve Light: draw the day yourself as points, each with a warmth or a colour.
Room-sensing Light: brightness from a lux sensor you already own, or from the sun’s height.
Each device exposes what it wants the lights to be as Flow tags, and there are two cards: Set lights the Lightkeeper way and It is dark enough.
Requirements
- Homey Pro (2023) or newer, firmware 12.9.0+
- A Personal API Key with Flow permissions, but only for Light Remotes and schedules, because Homey doesn’t let apps write Flows on their own. The key stays on your Homey.
Nothing leaves your Homey: no cloud, no telemetry.
Reporting a problem
Please say which device type it is, which lamp or remote you use, and what the app’s settings page (Settings → Apps → Lightkeeper) shows. That page lists recent presses and light changes, and why each was acted on or ignored. There’s more in the FAQ.
Built with AI, directed and verified on real hardware by me.
