Hi!
Will there even be a function to monotering enphase systems battery in the feature?
I am really pleast about monotering of the enphse inverters.
Thanks
/Anders
Hi!
Thanks
/Anders
The app polls Envoy every minute. How often it updates the information it provides is out of my control.
I dont use Enphase batteries so I’m likely to keep this as just a per-panel monitor.
So what does the energy attribute represent? It does not seem to be the amount produced today or total.
Anybody have any idea?
What do you mean with “energy attribute”. Is it in the Energy Tab or in the device tile or ….?
Just look at the unit, kW or kWh.
Aha, I have only power. I am on app version 1.0.11 experimental.
Could it be the power during this day. Have a look in Insights how the graph behaves.
I updated the app and have power and energy too. I have to wait a day to see what Energy means.
As I see in the notes the app is updated to make it compatible with the Energy tab, I presume it represents the total number of kWh produced from the beginning. Just as the Energy in the power meter of your house. The Energy tab uses that to calculate the current daily energy.
FYI: You can also use the group app, and make one groupdevice with power and energy.
I must be doing something wrong…
Whatever I do, the app keeps saying “no new devices found”
I tried both logins.
Anybody some tips?
The app never asks for an IP-address, but in earlier comments I saw something about changed IP addresses.
What do I need to set to get my panels in Homey??
The app doesn’t work for me either; the devices do not appear in the app.
I am having trouble setting up the IQ Insights app. The app repeatedly reports: “no new devices found.”
I have already performed the following troubleshooting steps, but the issue persists:
Uninstalled and reinstalled the app.
Restarted Homey.
Logged in using my standard Enphase web portal credentials (which work correctly on the Enphase website).
Does anyone have troubleshooting tips or suggestions beyond these steps?
Unfortunately same issue here, cannot find devices, created a7acda4a-64e2-4c95-84d6-66b053f515f2
No issues here anymore. Just tried to add my inverters and the app found them all
This app used to work perfectly. However since I had to do a restore on homey I get : this device is now not available. There is no repair option and there are no app settings. So I tried to add a new device, provided the right credentials and got no new devices found. I hoped that this would fix it, but it doesn’t.
Deleting a device and trying to re add also gives the same result.
7523ba83-e9e5-468a-b7a7-b5967ce26464
Hope you can find out what is wrong
Same problem! deleted app installed app homey reboot app will not find devices. Very disapointing.
Since two weeks experiencing the same issue. Strang thing is that this issue also seems to affect the “Zonnepanelen” en “Enphase” app. Wich for me indicates it is related to the API.
I am using the Zonnepanelen app and since a couple of days the app works again.
My problem was that at 0:00 hour the total of produced kWh that day did not reset itself. So it kept counting up every day.
It must be a coincident but after installing the last test version update of pbth it was ok again.
It has started when i had installed the version before of pbth.
My app isn’t working any more. All my panels have a red triangle. Rebooted homey, rebooted app with no solution. Enphase app and zonnepanelen app are working flawlessly. Can anyone confirm its app side or maybe my side? Don’t know what is wrong?
