[APP][Pro] Huawei Solar - Smart energy for a better life
Hi Mats
I’m waiting on replies from Huawei support in order to continue, but until then there is nog way for me to troubleshoot the web login.
My god… i overlooked :face_with_peeking_eye:
Appreciate all this info, I’m having issues and receive the Network request has failed notification. By Selecting the web integration do I still need an installers log in credentials? or should my usual Fusion solar credentials work. Thanks
Hi Pauly, it should be sufficient to use your Fusion Solar credentials.
Ok Thank you, maybe its the region selection. How do I find out what region?
Edit: I have tried all regions and still get the ( The provided credentials are not valid )
Hi, have you found any answer for this? I was under the assumption that active usage was the same as the load. But when i check and compare the graphs of active usage and PV output they are almost identical. They are only different when the battery is charging. Any updates?
The reason i wonder is that i would like to calculate the overproduction=pvoutput - load so that i can prioritized charging the car instead of selling. I hope that make sence.
Samuel
Hi !
I’ve just connected my Huawei solar! But unfortunately I have this error message …
Is anyone have the solution?
You can find the region when you log in into the fusion solar website, and then you check the URL.
Hi…a few days ago …fusion solar stopped working…i removed the app and device and try to reinstall the device but still the same “cannot read properties of null”
Any solution?
Many thanks…
I get the exact same error! Hope someone finds a solution.
Br,
Jonas
Try with the iosapp not the webapp…seems to be a difference.
it works again!
I have the same problem. What do u mean by “try with the iosapp not the webapp”?
Seems to be working again.
Hi Wouter, the app seem to work well and stable (at least for me) but one thing that seem strange is that generated power from the solar panels newer goes down to 0. Currently the app indicates 0.01 kW production (but no updates for the last 5 hours) Fusionsolar indicates 0w production which seems correct since its pitch black outside. Fusionsolar indicates 0w production for the last 5 hours.
Have you tried logging into the web version?
x
Hi @Thibau_Lgs,
Did you manage to find a solution or a workaround to get it working?
I have the same message when I add a device but no idea what should I do to fix it as in the past worked fine.
Many thanks
Unfortunately I didn’t find anything to make it work, I try sometimes to add the device again but that’s never works. I’m waiting for an app update…
Sorry
I’m getting the “Error retrieving data (TypeError: response.data.data is not iterable)” again. Dont know what happened. Worked fine before. I’m on 2.0.15 Test version
d80919ee-d1b0-491d-bbf0-e0adcf4e3d15
I have the same problem. Cant connect.
