Thanks for asking! The HYT-10.0HV-EUG1 hasn’t been tested with this app. The app talks to Hoymiles DTUs (DTU-WLite / Pro / Pro-S) on TCP port 10081, and auto-discovery only finds devices answering on that port. If the HYT’s built-in communication module doesn’t speak the DTU protocol, the app won’t see it.
Two quick checks would tell us:
Try pairing with the inverter’s IP address entered manually instead of auto-discovery.
Check if port 10081 is open on that IP, e.g. from a computer on the same network: nc -zv <inverter-ip> 10081
If the port is open but pairing still fails, please send a diagnostic report right after the attempt, and I’ll take a look.
The app uses the same hoymiles-wifi library as the Hoymiles Wi-Fi integration for Home Assistant. If you (or anyone) has the HYT working there, that’s a good sign: the protocol is supported, and any remaining issue would be on the app side, which I can fix with a diagnostic report.
Thanks for the quick reply! I am trying to set it up remotely, but the site is behind a double NAT, so I couldn’t run the nc -zv port test from the outside. However, I tried adding the inverter manually using the suspected internal IP addresses of the Wi-Fi module, but the pairing failed.
I just sent a Diagnostic Report right after the failed manual IP attempts. The Report ID is: 8dcc3be7-7a05-4819-9aef-e2fedecbc622
Could you check the logs to see if the app was able to reach port 10081 on any of those IPs, or if the connection was refused?
Thanks, the report was very useful. Here’s what it shows:
The automatic scan (empty IP field) found exactly one device with port 10081 open: 192.168.10.41. The other IPs (.39, .40, .47) don’t answer on that port, so you can ignore them.
At .41 the connection itself works (the port is open), but the device did not answer the first DTU request (device info). Pairing stops right there.
So the HYT’s communication module is listening on 10081, but it either speaks a different protocol than the DTU-WLite/Pro, or something else (like the S-Miles app or the cloud connection) is occupying it.
To find out which, there’s a small diagnostic script in the repo:
It needs to run on a computer on the site’s local network (remote desktop works fine):
It shows exactly how the device responds: timeout, refused, an error, or whether it only accepts encrypted connections. Please paste the full output here.
I’ll also add more detailed logging to the pairing step in the next version, so a diagnostic report alone will show this.
