[App][Pro] HomeKitty 😸 (aka HomeyKit 3.0)
@robertklep im still using the homeykit app, do u recommend switching to Homeykitty ?
If Homeykit works for you, there’s no real reason to, but development for it has stopped many years ago and HomeKitty supports more devices/features.
If using Homey Pro 2023 or newer I see no reason to use anything other then the official matter bridge from homey to achieve the same?
Does it support all devices and every feature that HomeKitty does?
does it do anything else than exposing devices to HomeKit?
How about you try both apps and see if there’s a difference :man_shrugging:t3:
Hi Robert, do you plan on adding support for robot vacuums?
Moved two Aqara H2 Dimmers (via Zigbee) from Aqara’s own app and M2 Hub and presented as Matter to Homey and then via Homekitty to Apple. Worked like a charm. Wanted to reduce complexity and connected them directly to Homey via Zigbee. They look ok in Homey but are presented as switchable only and no dimming on HomeKit (where dimmable there before). Any conversion problems through HomeKitty or…?
If you are missing device support, you can issue a feature request here: Sign in to GitHub · GitHub
Please create an issue here: Sign in to GitHub · GitHub
Hi - is anyone else still having daily crashes? I’ve tried experimental app but happens there as well. Early Homey Pro 2018 here.
Just submitted the request! Please let me know if you need more information
I have a flow that restarts my Homey SHS everynight. At each restart some of my Homekitty devices disappear from Apple Home. I hvae read this is due to Homekitty restarting to quickly. Is there a way to modify the Homekitty startup delay.
Yes, you can set an additional delay from the app settings:
Great I missed that. Do you think 30 seconds is too long
That’s probably (way) too short, set it to 5 minutes (300s) or so.
But I’m not sure if the issue that you have is related to this delay at all, especially if only some devices disappear from Apple Home.
That did not work. Any other suggestions?
Is there a common denominator between the devices that are missing? From the same app, all using Zigbee/Z-Wave/Thread/etc?
It’s a hue bulb. My hue stopped syncing devices so I am sharing them via home kitty
Can you create an issue here? Sign in to GitHub · GitHub
Please explain as much as possible about the situation (like if you have other Hue bulbs/devices that do work, and/or devices from other brands/apps, etc).
