[APP][Pro] HomeDeck – your whole home on one screen, in 3D and as a live floor plan
Nederlandse versie: HomeDeck
Hi everyone,
Floor Plan Dashboard is now called HomeDeck, and it has grown into much more than a floor plan. HomeDeck puts your whole home on one screen: your house in 3D with its energy, and every storey as a live floor plan.
This is still a test version. Not everything has been tried on many different Homeys yet, so all feedback is more than welcome: what works, what is odd and what you miss.
You can look around without installing anything, in the demo with a sample home: Huis (the editor is under the pencil).
Already using Floor Plan Dashboard? It is the same app, so your plans stay. Please read the update post.
What it does
  • Your house from outside in 3D, set up to look like yours, or a photo of your own house with your own tap areas.
  • Solar panels, grid, battery, car, heat pump, air conditioning, gas and water in their place, with thin power lines and calm values around the house. Tap a part for today’s chart, forecast and costs.
  • Solar panels on one roof half or on both, such as east-west, also in the solar forecast.
  • The sun stands where it really is, the weather follows the forecast, and in the evening your real outdoor lamps burn, as do the windows of rooms with a lamp on.
  • Tap a storey and you fly inside: live floor plans in 2D, 2.5D and 3D, with lamps that fade on and off.
  • At the top only what needs attention, such as an open window, the bins or the cheapest hours.
  • An “I’m leaving” check, buttons for moods and Flows, a night clock, the doorbell with its camera image, alarm, climate per room, who is home, media, vacuum, lists and the meals of the week.
  • Advice on what to do with your power right now, also as a Flow trigger.
  • A Flow can show something on a screen: the camera, a message, a storey or the Energy page.
  • Light, dark, as your device, or with the sun, and named screens that take their choices to a new tablet.
  • A Floor plan widget for Homey dashboards.
Everything runs as a web page in your own home network. A wall tablet, laptop or phone only needs a browser.
Energy
The Energy page with all blocks of Energy Dashboard is now part of the app. If you already have Energy Dashboard, the Energy button simply opens that app, with its own settings and history. Both keep working side by side.
The editor
You set everything up on a computer or tablet, in the browser: http://<your-homey>:8687/editor
  • Quick start from your Homey zones: every device starts in its room
  • Rooms of any shape: pull a blue plus on the edge for an L-shape
  • Doors, windows, furniture and lamps of the right kind
  • Under House you set up your home: type, roof, facade, surroundings and solar panels
  • You can also edit in 3D
Start from a picture
Do you have a floor plan from the estate agent (image or PDF)? Add it, measure one known length, and the editor recognises walls, rooms, doors and windows. This all happens in your browser; the image goes nowhere.
The widget
On a Homey dashboard the Floor plan widget shows the same live plan or your house, in Homey’s dark or light mode. In the widget settings you choose the plan, the level, the view and optionally a side panel with clock, weather and calendar.
Install
Test version: HomeDeck | Homey
  1. Install the app and open the app settings.
  2. Choose “Open editor” and begin with the quick start from your Homey zones.
  3. Set up your house under House.
  4. Open the dashboard on your tablet, or add the widget to a Homey dashboard.
An access code and an edit PIN are optional in the settings.
The full manual: homey-floorplan-dashboard/docs/manual.md at main · WNijhof/homey-floorplan-dashboard · GitHub
Feedback
This is still a test version, so all feedback is more than welcome. Reply below with what works, what is odd and what you miss. Even “it works fine on my tablet” helps me.
If something is wrong with a device, use “Report a problem” (the ! at the top right of the dashboard, or in the app settings). It makes an anonymous report without names or address. Send that report directly to me, by mail or private message here on the forum, not in this topic.
The furniture models are by Kenney, KayKit and Quaternius (CC0).
My other projects
  • Energy Dashboard: a live energy screen for every screen in your home
  • HomeWindow: control your Homey Pro from the Windows taskbar
Want to give something back? You can on Ko-fi, with the button below. The app stays free, a donation is entirely voluntary.
Support on Ko-fi
Sounds cool!
Do you have a screenshot of the Homey Widget and how that looks?
Thanks! Here is the widget with the demo home. It shows the same live plan as the dashboard, in 2D or 2.5D, in Homey’s dark or light mode. Tap a lamp for its controls. In the widget settings you choose the plan, the level, the view and how it is turned, and optionally a side panel with clock, weather and calendar.
I have added these to the first post as well.
Update: 0.2.0 is on the test channel, and Floor Plan Dashboard is now called HomeDeck
This is the biggest update so far. It is still a test version, so all feedback is more than welcome, even if it is only “it works”.
Install: HomeDeck | Homey
It is the same app with a new name. Your plans and settings stay. From this version you can export everything in the editor under Backup, and the app also makes a copy of its own before each update.
What is new
  • The dashboard opens on your house in 3D, with its energy. You set that up under House in the editor. Prefer to start with a storey? Choose that under the gear, per screen.
  • The Energy page is part of the app. If you already have Energy Dashboard, the Energy button opens that app, and nothing changes there.
  • Solar panels can lie on one roof half or on both, such as east-west.
  • At the top only what needs attention, and there is an “I’m leaving” check.
  • Buttons for moods and Flows, night clock, doorbell, alarm, climate per room, who is home, media, vacuum, lists and the meals of the week.
  • Lamps fade on and off.
  • The left bar of the editor has labels, and there is a quick start from your Homey zones.
  • Rooms can have any shape: pull a blue plus on the edge, or choose Make L-shaped.
  • There is now a manual: homey-floorplan-dashboard/docs/manual.md at main · WNijhof/homey-floorplan-dashboard · GitHub
What changed
  • There is one 2.5D view left, the higher one. If you used one of the other two, your screen or widget switches to it by itself.
  • Furniture from one model set stood back to front and has been turned around. If you turned a piece by hand, it may now stand the wrong way. Select it and turn it back.
  • The house has a smooth dark facade by default. You can choose brick or white plaster under House.
  • Dimmable devices now count as lamps, even when their app reports them as a socket.
How to start
  1. Update the app with the link above.
  2. Open the editor, choose House and set up your home: type, roof, direction of the front and solar panels.
  3. Do you have a level for the rest, such as garden or basement? Name it Other or Basement, for example, and it does not count as a storey of the house.
Please help
I have not been able to try this on many different Homeys yet. I would especially like to hear how this works for you:
  • the speed on your tablet
  • moods, Flows, doorbell and alarm
  • the Energy page without Energy Dashboard
  • the widget on a Homey dashboard
If something is wrong with a device, use “Report a problem” (the ! at the top right of the dashboard) and send the report by mail or private message, not in this topic.
Great work! I’m trying to get the floors in the right order. Now my second below the ground and first floor.
From the settings app in safari Mac, the shortcuts Open Dashboard and Open Editor don’t work. On my iPhone they do work.
Export will always export the same floor: ground floor
Edit: export will export everything, all floor and layout.
I managed to reorder my floor levels by eating the export and import it again.
I really impressed how nice it is working and the looks of it
@WNijhof Looks promising, will it be possible to use already created floor plans from apps like Sweet Home 3D or already rendering images?
Update: 0.2.1 is on the test channel. Install: HomeDeck | Homey
@Hullie Thanks, and good find with the export. You no longer need that detour: in the editor, click an empty spot beside the plan and use Move level down or Move level up. The first level is the lowest one.
The Open the editor and Open the dashboard links in the app settings now use Homey’s own way to open a page. I could not test this on Safari on a Mac myself, so please tell me if it works now. If not, the address below the buttons can be copied into a new tab.
@Daniel_Fille Yes for pictures, not directly for Sweet Home 3D files. Under Picture in the editor you can load a picture or PDF of your floor plan and set the scale by measuring one known length. Then the editor can recognise walls, rooms, doors and windows, or you can use it as a background to trace. From Sweet Home 3D, export the top view as a picture or PDF and use that; a plain 2D plan works best. The result is always drawn again as HomeDeck’s own rooms, so a rendered image will not be shown as it is, and 3D models from Sweet Home 3D are not imported.
Also new in this version: open up a wall between two rooms (Open wall), place the same device more than once, and curve a free wall.
Yes, the shortcuts are working on a Mac from the homey app settings.
Always the level up and down working fine.
Thanks for the clarification :grin:
Update: 0.2.2 is on the test channel.
Thanks for confirming that the links in the app settings work on a Mac.
What’s new:
  • The 3D house can now follow the shape of your floor plan, including an extension. In the editor, go to House, then Shape of the house, choose between the simple block and the shape of the plan, and set which side is the front.
  • A hot water boiler known to Homey is a card on the facade, with its temperature. Tap it for the target and the hot water left. Turn it on or off under House in the editor.
  • Heat pump, charger and meter sit on the real outside walls, also on a house with an extension.
  • The labels about the front of the house in the editor are clearer.
  • The advice on the dashboard now opens the Energy page.
  • On a phone, the names of the levels stay in view.
I could not test the boiler on a real Homey yet. A device Homey knows as a heat pump or heating boiler still shows up as the heat pump. Please tell me if your boiler is missing or looks wrong.
The stacking of the floors in ‘shape of the plan’ does not work in my case. I have 3 equal floors stacked but the top floor is 50% off. Could be caused by that I had to move the rooms around on that top floor?
The buttons on top on the left: clicking batteries low does not give more info. Contact sensor opens ‘I’m leaving’.
‘Vacuum cleaner’ button: I don’t have one :roll_eyes:
‘I leave’ button: it should be configurable, now it want to turn off that should not by turned off.
Thanks for testing and for the clear list. All of it is in 0.2.4, and 0.2.5 is now on the test channel:
  1. Stacked floors: storeys of the same size now stand on each other in the house shape, also when you moved the rooms of a level in the editor. That was indeed the cause.
  2. The chips at the top: the low battery chip now opens a list of the devices with a low battery, and the chip for open doors and windows a list of what is open, instead of I’m leaving.
  3. I’m leaving: untick a lamp that should stay on. The screen remembers it, so the button for all lamps off leaves it alone.
  4. Vacuum button: it only shows when Homey has a device it knows as a vacuum cleaner. You can turn it off under the gear (Vacuum button). Which device of yours could be taken for one? Then I can make that check stricter.
Nice work!
Stacked floors are nicely aligned.
All chips are working and/or configurable.
You’ve created a really great app!
Is it possible to use an existing PDF floor plan so that the rooms are recognized exactly as they are drawn—even with non-standard angles—without having to redraw everything from scratch? And could that then be rendered in 3D? In my house, part of the second floor sits under a sloped roof, which currently isn’t being captured. I would also like to include the garden, along with a garage and a separate garden shed. Thanks in advance for your response!
Thank you! All three of your wishes are in 0.2.7, which is now on the test channel: HomeDeck | Homey
PDF floor plan: start a plan from a picture or PDF and set the scale by measuring one known length. The editor then recognises walls, rooms, doors and windows, now also where walls run at an angle, and the result shows in 3D. Your file stays in your browser. Please check the result: so far I have only tested this on test drawings, not on a real PDF, and curved walls are not recognised. I would really like to hear how your PDF comes out.
Sloped roof: click an empty spot beside the plan and, under Sloping roof, tick the sides of the drawing where the roof comes down, or choose Like the roof of the house. Then set the height of the knee wall and the pitch. In 3D the walls follow the slope and windows in a low knee wall get lower. The slope is set per level, and the roof surface itself is not drawn in the level view, so furniture can stick through it.
Garage and shed: make a level called Garage and one called Shed (Schuur or Tuinhuis also work). Each stands as a building of its own in the garden of the 3D house, with the size of the rooms you draw in it. Tap it to open it. Under House, at Garage and shed, you choose whether it stands beside the house, at the back of the garden, or not at all.
Garden: make a level called Garden and draw it the same way.
Thanks for checking, good to hear. If the vacuum button still shows up without a vacuum cleaner in your home, let me know which device it is, then I can look at why Homey sees it as one.
I don’t want to be annoying, but I see one of the options by house type: a detached house, a 2 under a roof house and an intermediate house. However, I miss flat house and corner house as options. Now a corner house can be accommodated by 2 under a roof, but a flat house cannot. Possible to implant these options.
But it is a nice project. :melting_face:
Not annoying at all, thanks for asking. Both are in 0.2.8, which is now on the test channel.
Corner house: under House, at Type, choose Corner house and the side of the neighbours. The row of houses then goes on at that side.
Flat: choose Flat (apartment), then set the storey your flat is on (0 is the ground floor) and how many storeys the block has above it. The flat stands in a block with neighbours on both sides and a flat roof, and tapping it still opens your own floors.
Version 0.2.9 is on the test channel, mostly from wishes in the Dutch topic:
A room can do without walls of its own: select it and turn off Walls around this room. Handy when your living room, dining room and kitchen are one open space, or when you draw the walls yourself.
An open wall in an outer wall is now really open in the 3D house, from the ground up to the floor above, such as a drive-through or a carport. This works with Shape of the house set to Follows the floor plan.
The front door goes on the door you drew in the front wall. Under House you can also choose it yourself at Place of the front door.
Kitchen units take the colour you choose on their body and fronts; the worktop and sink keep theirs.
A virtual device is no longer taken for a robot vacuum, even when it has that class.
Picture recognition now also finds rooms filled with a dark colour, such as a garage or a tiled bathroom, instead of taking them for walls.
First of all: great app! I set up HomeDeck today for our home, a three-storey corner house, and it was easy to do!
While setting it up I did run into a few things. Some ideas:
  1. Movable grid connection
    The grid cabinet is fixed ~3 m beside the house, on the side without a driveway. For our corner house (neighbours on the left) the connection therefore comes in at the neighbours’. It would be nice to choose the location yourself, or to show both the electricity and gas connection in the meter cupboard.
  2. Movable air-con outdoor unit
    The outdoor unit is fixed to the front wall. Ours is on the side wall above the shed. It would be handy to be able to drag the outdoor unit to its place.
  3. Dormer at the front
    The option is currently “Dormer at the back”. We have a ridge-raising dormer at the front. It would be handy to place it at the front and make its size editable, as well as a “ridge-raising” option.
  4. Chimney on/off
    Every gable roof automatically gets a chimney. An on/off option would be nice.
  5. Sloped roof on an extension
    Everything outside the main block now gets a flat roof. Our former garage has a lean-to roof that slopes down to a small flat section. A pitch per part or room would make that possible. The walls are already shown with this slope, but the roof of this part is still shown flat.
  6. Customisable garden
    I drew the garden on its own tab, but the 3D house shows a standard garden. It would be great if the drawn garden also appeared in 3D. That way you could also include the lighting and possibly irrigation.
  7. Customisable neighbour house, with mirroring
    The neighbours are placed automatically and don’t look much like reality in our case. Settings for width, depth, offset and roof shape would help, and a “mirror” button (neighbour house = mirrored own house) would be really handy.
  8. HomeWizard Energy Sockets & Toshiba AC are treated as lamps
    The Energy Socket has a dim value for the brightness of its LED ring, and Toshiba AC has a light as well, so HomeDeck treats it as a lamp, even when its class is socket. Result: a lamp icon, and “I’m leaving” can switch it off. It would be nice if these applications (and possibly others) were recognised correctly, or if you could choose “show as socket/AC/Etc.” per device.
  9. I have the Hue Dial Switch. Would it be possible to show it as one switch with its 4 buttons, so that when you select it, you can choose one of the 4 options?
Happy to help with testing or more info, and I can send screenshots if that’s useful!
