[APP][Pro] HDL Smartbus
Great @ojnordah - thanks for testing!
I’ve asked Homey to review and release the 1.5.0 version from test to general availability. I’ve been merging some more fixes after that, but they are not on test yet, as I can only have one at a time. This means that the status in the wishlist might be different from the released version, and this is the case in regard to the floor heater module in case you wanted to test it during the weekend. As soon as Homey approved vs. 1.5.0 I’ll release 1.6.0 to test, which has the following content:
New features
• Floor heater: pair digital sensor probes by typing the probe ID (#115), and pair sensor channels as read-only temperature devices (#110)
• UV send modes and universal-switch signal logging/diagnostics (#106)
Bug fixes
• Dimmer no longer flashes to 100% before setting the requested dim level (#111)
• Universal switch: status-less signals no longer crash the app (#114)
• Curtain: unparsable short 0xE801 duration responses are skipped safely
Under the hood / other
• Upgraded to smart-bus 0.10.0 (raw-payload workarounds upstreamed and dropped, #117)
• Relicensed from GPL-3.0 to MIT (#113)
• Documentation overhaul: Docsify site with search, heating DLP sync guide, moving-logic-to-Homey guide, contributor docs
Andreas
  1. Which HDL module are the magnetic contacts physically wired to (e.g. a dry contact module, multisensor inputs, something else)?
    Dry contacts module
  2. Was routing them through UV switches a deliberate choice, or just how the system was set up?
    this is how I set it up, it works fine with i3 lite app. And it works in logic module with screens.
Thank you for your reply @Andreas_Pedersen. If you just pair the dry-contacts module directly you get the read-only result you want and it should also be easier to trigger flows from it. I would avoid using Universal Switches for it, given the amount of “noise” they create. Let me know if I’ve misunderstood the request as I’m setting the wish list item as solved.
Regarding the floor heaters, is there any work planned on adding the opportunity to add the size of a heating cable connected to the channels on the floor heater, so it would be listed to the Energy tab? Should be “triggered” depending on the valve condition.
I asked the AI agent to look into it, and it came up with a solution. Will be added to a later release (there is a queue now waiting for Homey verification):
Let users enter the heating cable size (watts) per zone in the device settings. When set, the zone gains an approximated measure_power capability that reports the cable size while the valve is open and zero while it is closed, so consumption follows the valve condition rather than the zone enable switch that Homey’s standard energy approximation would key on. Setting the size to 0 removes the reporting again, and digital sensor channels never get it.
I have used the test version for a week now, and do experience faster response time :raising_hands::raising_hands: so only positive feedback and really great work :+1::+1:
Version 1.5.0 is now the official release and 1.6.0 is the new test version. See release notes a few post above.
Version 1.6.0 is the latest release and version 1.7.0 is in test with the following change log:
  • Added DLP Heater for supported DLP panels running floor heating: room temperature, active setpoint, mode and power are shown in Homey, and can be changed from Homey or Flows, including Flow cards to set the mode and setpoint, press a configured panel button, and a trigger when the thermostat mode changes. DLP panel buttons can also be pressed directly from Flows.
  • The 12in1 multisensor relay outputs can now be controlled from Homey.
  • Floor heating zones now show approximated power usage in Homey Energy
Great work by @ojnordah on the DLPs!
Outstanding work! This will make a huge difference. Can’t wait to test out the DLP-stuff.
