Unofficial app for the Govee WIFI enabled devices. This app supports the main light functions as they are available in the Govee API.
Getting started
For Lights (using the cloud API) and the Appliances:
You need to use the Govee app to request the API key for you account.
Then after installing this app you can set the API key in the app settings.
Then you can add the Govee devices.
For local Api devices ensure you enable local API on every device you want to use like this
Check if your device is supported here:
Supported Product Models (govee.com)
Currently the app supports the:
Cloud api enabled lights
Beta: Cloud api Appliances
Local api enabled devices
Cloud API devices (main release)
The Govee API does only allow basic light operations (see Test section for more features), these are:
turn on/off
set color
set color temp
set brightness
no Bluetooth lights
If you set your bar to a color mode, both bars will use that color in full. There is no way to switch back to video mode without the Govee app unless your device support snapshots.
And its available now:
Local API devices
- The local API devices are much fast in response and dont require cloud support
- The local API devices will not impact your API throttle limits from Govee, so really helps to solve those kind of issues.
- The local API devices seem to allow you to add the same light multiple times. These could cause troubles, so I advise against doing it.
- Local API devices dont know their name, or they dont expose them, so you only get the device type. You can enable/disable local api support on devices to add them on by one.
- Local API devices require discovery time, after the app starts/restarts it may take a minute or so before all devices are discovered and available (wont be ‘solved’)
- Local API devices wont receive updates on colortemp changes (they do when you swicth to colortemp mode) made by other apps like the Govee mobile/light app etc, all other updates should be handled really quickly (needs an 3rd party fix)
Test channel
In the test channel there is a rather big new version available that is the first steps in the rewrite to API v2.
- Allows for Light scene control (Flow and bad UI)
- Allows for DIY Light scene control (Flow and bad UI)
- Allows for activation of snapshots (Flow)
- Allows for control of segments (Flow)
- Allows for activating the Musicmode (Flow)
- Allows for activating DreamView (Flow and bad UI)
For the different modes it is not possible to know in what mode the device is, so status might get out of sync (like the dreamview mode) - All devices now have an Online alarm support
- Local devices can now be enabled to enhance the device with the advanced features through the cloud, see device advanced settings to enable it for a given device
- Homey cloud is now support (beta)
Appliances
- Appliance support has split into more dedicated appliances
- Thermometer is supported
- Other appliances support only on/off at this moment
