That is a good point. I would then deprecate the Set single phase charging to card and introduce a new one for the phase selection action. I.e. Set charging phases to [[num_phases]] where num_phases is an enum that can be 1 or 3.
Indeed, there is value slider stepping of 2, I will fix that to stepping of 1. Not really sure why it became like that.
Hello
unfortunately go-e charger app for homey pro 2019 showed me today error and it is not working at all because there is some problem in temperature. After my go-e charger increases temp to more than 50 degrees the device is unavailable and shows this error: Measured temperature out of rangeerror:51is greater than 50 (out_of_range)
Go-e cahrger is still working. After the temp decreases less than 50 °C it is back working in homey.
Could somebody help me please fix this?
Thanks a lot
Patrick
FIX: Increase “measure_temperature” capabilities max value to 70C.
@Patronick , test version has a fix to the max value for temperature. You can install test version, or wait for Athom to approve the new version to live version.
Thanks for a great job! Can’t imagine how long takes Athom to improve a new version if we speakabout hours,days, weeks… so I will see… than youso much and have a great day!
If the Fronius mobile app is near the go-e app, then you could try:
enable API v2 from “Advanced Settings” and try to go to http://IPADDRESS/api/status and PM the output to me, if anything.
As far as the charging station is concerned, the hardware is the same between Fronius and Go-e (Fronius simply re-brands Go-e stations), but not the software. Actually, several years ago when Fronis released this charging station, it simultaneously released the Fronius smartmeter, which communicates directly with the station and enables electric vehicles to be charged using excess power. If that’s what you want to do, you might as well buy a Fronius smartmeter that communicates perfectly with the Fronius charger. Connecting your charger to Homey would be of little use because if you only want to start or stop a charge manually or with simple programming, the Fronius app will do that just fine.
The problem is that the Go-e chargers also came out several years ago, but the compatible smartmeter only came out a few weeks ago. But as Go-e’s policy was to open up its system completely (unlike Fronius, which does everything it can to keep its ecosystem closed…), it became very interesting to have an app compatible with the Go-e charger, in order to programme charging using excess power, as I’ve done here, for example.
That’s it, I think it was important to give this little background to understand the very different policies of the two companies, and why it’s very useful to have an app for the Go-e charger and not necessarily for the Fronius charger for those who already have a Fronius smartmeter. Once again, many thanks to Tapio Heiskanen for this excellent app.
I have Fronius ecosystem (Gen24 inverter, BYD battery) and the charger is coming (even without having a car now, but that will be the next :-)).
I hope Fronius is doing all right automatically (surplus loading) but I would love to change settings via Homey. So I checked what could be compatible.
I’ll check this out when all is installed
No result on this URL, too. But thanks for taking a look at it.
I also think a new apps would be best.
First I try the HA integration. With my HA community app I can get all entities easily into Homey. And perhaps if I have too much free time I can create a Homey app
I have a problem with the condition card “charging”. I have couple of times noticed that all the sudden it doesn’t work. It doesn’t happen often but sometimes. The go-e charging device shows that the charging is active, but the condition card doesn’t go through. Also the status page of the go-e charger shows that the value of the car connection “car” is 2, which means it’s charging.
