[APP][Pro] Flow Checker
Just fixed all my flows today. Not sure if any are still broken (missing an app that tells :wink:)
I will sent the report via a pm
New app update (:orange_square: TEST: 1.29.0.):
1. NEW: migrate to Homey Compose
2. NEW: Preparation for dashboards :soon:
More - apps - Flow Checker - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Flow Checker | Homey
Icon of flowchecker messages was this morning just a black dot. Had testversion 1.29.2 installed.
Deleted it and tried to install the product version. Got the info: it will be installed shortly. Tried a few times, it won’t install.
Using homey 2023 pro with 12.1.0 and iOS App testversion 9.0.0.1565. With the beta App on Android the same behavior
@SingKT I’m not in control of installing a app. But the icon should still be there :thinking:
Maybe try a Homey reboot?
Thanks, after a reboot of the homey the install of Flow Checker worked
New app update (:green_square: LIVE: 1.29.6.):
1. NEW: Dashboard Widget
Hi Martijn
I’m not sure if this issue is raised before but I have an issue with flow checker when Homey does a reboot. I get several notifications about broken variables (picture 1) however when checking these flows they don’t seem broken.
Also if I do a manual flow check (picture 2) I don’t get faults.
Perhaps this has something to do with certain variables not being available during a reboot?
@Marcus_Bitterling theres a setting for that. If you uncheck check flows on startup you won’t have it
Thanks! :+1:
Flow Check is a nice app. But it would even beter if it will point out wat is broken.
For example i get the following error “FlowChecker - Event: BROKEN_VARIABLE - Flow:”
The Flow is a advance flow with al lot of Variable. Would be fin if it would tell me wat Variable is broken.
Hey @Ronald_Bok
Thanks
Actually that’s not really possible as when a variable is broken the reference to the variable is broken causing it to be broken in the first place but also it’s unknown for flow checker wat variable it is or to get the name
@martijnpoppen -
Much appreciated! :smiley:
@Marius_Stensrod youre welcome!
Hey @martijnpoppen ,
After update of a app, a flow card for one device was removed from the vendor of the app. The “When” card turned grey, and the tag i was using in next flowcard was also grey. But I did not get any warning from FlowChecker.
My warning flow looks like this:
Settings FlowChecker:
Running HP23, v12.2.0-rc.3 . FlowChecker v1.29.4 .
Is this known for the HP23 with this FW?
@Marius_Stensrod hard to say
Please send a diagnostic report
If you still have the error
Sorry, repaired the flow before i thought of that I had not got any message about it.
I have now again a broken flow without reporting from Flow Checker.
Flow (Name: Kjeller-Lys tenner og slukker automatisk):
Flow Checker:
-FlowChecker version 1.29.4
-HP23 version 12.2.0
-Diagnostic Report: f6b10914-56b1-4812-a106-4abb57d9eff6
I do think that this flow, should be marked “broken flow”.
Hey @Marius_Stensrod
yes known issue but unfortunately i have to wait for this (WebApi V3 Flow IsBroken() promise false positives · Issue #53 · athombv/homey-web-api-issues · GitHub) to be resolved
New app update (:green_square: LIVE: 1.30.3.):
1. NEW: added option to enable notifications for FIXED flows and FIXED variables (see app settings)
What is the meaning of “FIXED flow/ variable”?
Is it a flow that was reported as broken and is no longer broken?
