Hi @martijnpoppen, for some time now I have seen in the daily overview that I run in a flow that there are several (29) flows with broken variables.
When I check these flows I see nothing strange and therefore no defective variables.
What does the app base on when a variable is broken and can it also show which variable it is?
Not sure if you need it but this is the app report.
Hi @Heula
Depends on the variable. In the timeline it should also specify which variable category is broken. The variable itself cant be logged as FlowChecker will only fire if the variable is not there. So then the variable will always be unknown
@martijnpoppen That is just it, I don’t get any timeline notfications for any kind of issue from Flow checker.
Only the one that I run each day on a specific time and only shows me what I have chosen to show in the timeline.
@Heula probably because they are marked as broken for a while now. Only when flowcheckers finds new broken variables/flows it will trigger a notification. Otherwise it will spam the whole day.
You can reset flowchecker to default settings in the app settings and then run the flowchecker flowcard to see what is broken. It will log again to the timeline
@martijnpoppen After resetting the settings, the same results appear after running the check card.
Again I do not see the issue and also I notice no issues with all these flows.
I only was wondering why Flow Checker tells me there is an issue with certain flows and or variables where it seems to be fine in those flows.
@Heula then probably flowchecker is not properly checking flow utilities and therefore giving a error on it.
no way to ignore it. should be fixed in the app.
so if you can share some of the flows which are marked as broken i’ll try to reproduce and create a fix in the app
@martijnpoppen It looks like flowchecker does not show matter devices.
I have connected my hue bridge via matter.
Last week something broke and all matter devuces (via hue) were disconnected. I decided to remove the node and load them again.
Flowchecker would tell me what flows had broken…, I thought…
