[APP][Pro] Flow Checker
I also have more fun hobbies :rofl:
@Sharkys @Kai_Engvik The broken flows are not discovered by Homey and it’s missing from the API response.
I already contacted Athom for this
Thank you, so no need to provide
Homey.flow.getFlows();
…probably another Athom’s optimisation. ;-(
I already couldn’t believe I had zero broken flows :rofl:
Yesterday I installed this app. Version 1.2.2
According to the app I have 61 broken flows. All Better Logic variable errors.
Is this normal? :slight_smile:
@iBosvelt the app was updated to the new Homey API. So there might be some errors.
Best is to send a diagnostic report
See: [APP][Pro] Flow Checker - #625 by martijnpoppen
New app update (live: 1.22.2.):
1. FIX: BetterLogic
2. FIX: Flow Utilities
More - apps - Flow Checker - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
@iBosvelt v1.22.2 should fix the BetterLogic vars again :wink:
Thanks for you hard work, Unfortunately I’ve got the same “Betterlogic” problem with 1.22.2
6eb43430-ac08-4410-991e-306ddab8b322
@Arjan-21 thats strange, i fixed that yesterday. Unfortunately the HP23 logs are so short theres nothing useful at all. So i have to try and reproduce it
Can I help with some additional info?
@Arjan-21 yeah maybe share the type of variables you have an a example flow which is marked as broken. :slight_smile:
@Arjan-21 also can you run a update broken flows and variables flowcard once to see if it still indicates BetterLogic vars? I really can’t see why it wouldn’t work :confused:
@martijnpoppen I’ve run the “update broken flows and variables”, then deleted all the betterlogic cards in 1 flow and updated it again. That flow was “fixed”.
, but after adding BL Vars it was broken.
Tomorrow I will take a look to see if it is a certain type of Vars
@Arjan-21 Thanks!
Will try to produce some error here as well :stuck_out_tongue:
@martijnpoppen I have tried to put each BL card in a flow and then update Flowchecker, but with every card I get a message that the flow is broken. (I didn’t do it with the making up of date etc.)
@Arjan-21 I tried the same but cannot produce a broken flow with it :frowning:
you are on version 1.22.2?
@iBosvelt quick check, do the BL variables work again? :slight_smile:
Martijn on Slack or Github ? I just know it’s like that since beginning on HP23, probably since the new API ? ;-(
@Sharkys I sent a message in AATP :wink:
and also github: WebAPI Flows don't return "broken" · Issue #44 · athombv/homey-web-api-issues · GitHub
