[APP][Pro] Eufy Security
All cameras down as if they were not detected by homey. Happened multiple times this morning. See image attached to email
(attachments)
@Andrea_Boletti that’s a app crash
Next time that happens send a report
Thank you! I figured out what I did wrong in the login procedure. I have downloaded the Eufy apps in Homey now. Thanks again! Guus
Hello Martijn,
Thanks for this great App!
I cannot add my device. It says it is not found.
I have created a diagnostic report if needed: 4850880f-71f2-4d83-8315-9293043f07a
The device is shared and I have successfully used that share. What am I missing?
@i2Paq thanks
As far as I see, you’re missing a correct password :smiley:
[EufyLibrary] [http] [HTTPApi.login] Login - Response code not ok {
  code: 26006,
  msg: 'Email address or password incorrect.',
  data: {
    code: 26006,
    data: null
Thanks!
The (your) App does not like an @ in the password :blush:
Works now!
Thanks for the fast reply, I will buy you a beer! :clinking_beer_mugs:
@i2Paq that’s interesting :thinking: I’m pretty sure i have a password for one of my eufy accounts with a @ in the password. will check!
Thanks a lot for your kind donation! :folded_hands:
Hi Martijn, when do you think the fix will be released for Indoor Cam 2k? Just so you know I reversed the action cards for turn on/off for away /home and it works well as temporary workaround.
@Akeran i hope somewhere next week. Currently a bit limited in time to work on Homey apps
I understand, no pressure. Thanks for your support and time.
Hi Martijn,
Did you perhaps already had some time to have a look at the Eufy E340 doorbel generic alarm not being implemented in the SDK? I just tried and it still isn’t available, so just wanted to make sure it is not only an issue for me. :smile:
@Bear84 [APP][Pro] Eufy Security - #7063 by martijnpoppen
So if I had time I would have told you
Hi Martijn, I recently bought an C220 Cam and with your explanaition I was able to connect it to Homey. Now I am trying to toggle on/off Nightvision in Homey Flow ,because the camera seems to be always in Nightvision when it is put in auto mode, but it doesn’t seem to work. When I send another command e.g. turn 360 the camera reacts to this command so there is a connection between Homey and the camera.
thanks in advandce for your advise
hi @Mike73
please send a diagnostic report
3179c3fd-7c83-4c6f-96f7-9a8b0f530b68
@Mike73 seems like this is missing in the SDK. I add it to my list with things to fix. Currently not available to work on Homey app development. I hope somewhere next week :slight_smile:
that would be great? :+1: thanks
Hello Martijn,
I have troubles with doorcontact and pir modules the changes/warnings will not show up in homey eufy app.(use 3.31.2) When i look in the eufy app it works. for example I open the door it show it is open but when i look in homey it doesn’t change at all.
(from the past you advised to restart eufy app every night so I added an flow for that)
Is there anything I can try to find the reason for the error? Log f9fe6f5f-81f1-4510-9278-889c88504420
@Michael_PA4MIC see FAQ Q1 [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum
Hi @martijnpoppen,
I was away for a couple of days - but did some investigation now.
Created two test flows and had them running in parallel just to check what’s going on.
In the S380 flow (named “Inkørsel”)the faces are recognized in the Eufy App and a push is sent via the Homey app.
From the E340 doorbell flow (named “Hoveddør”) a push is never sent but in the Eufy App the faces are recognized.
So either the face recognition is never sent from the Eufy Homebase 3 to the Homey App when a face is recognized via the E340 doorbell or there is something wrong with the #person tag when it comes from the doorbell.
