Thank you for the support for the Solocam C210.
Are there any plan for adding additional flows?
I would like to be able to change the arm mode and use Motion/Human detected to start a flow.
I make use of your Eufy security app for my Homey Pro, thank you for making this, It’s great to be able to integrate Eufy with other sensors and devices.
However, it finds all of my Eufy devices except for one.
it’s the E340 Floodlight camera with 2 lamps on it.
The camera is connected to the homebase 3, but when I search for it through “add devices” via the Eufy app and log in it tells me no devices have been found.
Is this a known thing, or am I just missing something.
Thanks for pointing it out. I see my app is still on version 3.22.0, but I have automatic updates enabled, so I’ll await the testing and hope it comes through soon
Last night I got notifications in Homey that captcha was required. And after repairing the app in Homey, I’m getting the same results as before. My flows won’t start on the triggers from the eufy doorbell.
After re-installing the eufy app in homey, there is another tile for movement of pets, which isn’t a feature as far as I know. Still all flows don’t work.
Push notifications are enabled. When logged in with the account on a phone, I get the push notifications.
I remembered I had an Eufy cam2 as well. I installed the cam, and it gives the same problems. It’s showing up in Homey, but doesn’t register movement in Homey. First time it showed the option for pet movement. Second try out didn’t show that option anymore.
Doorbell didn’t show the option for pet movement as well in the latest trial…
Furthermore I noticed that when adding the homebase2 to Homey, the standard setting jumps automatically from “thuis” to “uitgeschakeld”.
Hi Martijn,
does 3.23.3 now also the long awaited battery fix for the S340? Mine it still dead, I was wondering if I have to hard plug and charge first before getting it up and running again?
I cannot login using my Eufy account which is not 2FA enabled because my region is Australia. The app only allows EU and US. If I log into another region it says that I will lose everything . It says to create a secondary account in the app. Where in the app eufy do I creat this secondary account? Can make so that I can use my own region?
