[APP][Pro] Eufy Security
@F2023_F can you try to pair once again and send a diagnostic report after that?
Sorry but how can i send a diagnostic report?
@F2023_F
you can send a report via the mobile homey app
More - apps - Eufy Security - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
I have send the diagnostics report. Would you like to know the ID of the report?
@F2023_F not needed.
But the logs say that your username or password is invalid
I’m logged in and then receive the message “Please add a homebase before adding this device”
For new login, press Vorige
@F2023_F so you have to add the Homebase first :wink:
Hi Martijn,
I choose the video doorbell and when I choose for that I saw a picture of the video doorbell and the homebase so because of that I didn’t add a homebase first. Now I have first selected the homebase and after that the video doorbell, problem solved!
Many thanks for your support!
@F2023_F Great! :tada:
Hi, i need the Eufy Homebase to include the Eufy Camera? Or it´s works without the Homebase. Solocam C210 , Homey Pro
@Robin_Heidemann it doesn’t need a Homebase, but it’s not supported yet in Homey.
@Aybee see [APP][Pro] Eufy Security - #4 by martijnpoppen - Apps - Homey Community Forum Q1
Yes, i have see this to late, now it works :slight_smile:
Thanks
Just received a Dual Doorbell Battery E340 (T8214311) But cannot get it to connect. I have it added to my Homebase 3 as I have with 8 other cameras which may be added perfectly. Tried all 3 different doorbells to no avail. Any suggestions?
W8ing for this as well!
Even worse is that the halloween scares depends on it :pleading_face:
@mblom74 see: [APP][Pro] Eufy Security - #4418 by martijnpoppen
Im still waiting on the library. Nothing i can do for now
In a flow I change the security mode of my Homebase 2: every evening to the mode “Slapen” (Custom 1) and every morning to “Thuis” (default present in the Homebase). No problem.
But, when I want to do the same with my Homebase 3, I saw that the change to “Slapen” (Custom 1) has no effect. Trying changing to other security modes also has no effect. So, the security mode of the HB 3 stays the same.
Even a simple flow (when this flow has started, then change security mode of the HB 3 to …) has no effect.
Is this a known issue, any ideas of a solution?
@Roger_Gorissen yep couple of things you can try
  • restart Homebase
  • restart Homey
Thanks, restarting the Homey did the job!
