@Michiel Alright thanks will dive into it!
New app update (live: 2.35.3):
Changelog:
1. FIX: leftover from old Camera Alarm removal for Eufy 2C Pro
2. NEW: add extra options for arming icon
3. FIX: alarm arm mode settings
Question: I’m looking into buying a Eufy Video Doorbell. If connected to Homey running the Eufy App, will the doorcam be visible/usable in Homekit on my iOS devices? I’m running Homeykit for Homey-Homekit integration.
For instance, if someone rings the bell, would Homekit send me a pushnotification on my iPhone and give me possibility to view the videofeed en talk to the person at the door?
Second question, would it be possible to use my HomePod’s as chimes via Homekit Automations?
I hope someone has experience with this chain/setup.
Hi @B-lex
I’m not using HomeyKit myself. But what I can say about some parts:
This wil not be possible. The only way to stream is using the weburl which I made a flowcard for or use the official eufy app. It’s not posssible to get this stream in Homekit. Maybe you can do something with Apple shortcuts when a message comes in? ![]()
If HomeyKit can react on notifications you won’t even need Homey for that. But not sure about that ![]()
Hopefull there’s someone in this thread who uses Homeykit and Eufy ![]()
Hi @martijnpoppen - would it be possible to implement a flow card in the “Then” section that says “Reboot Homebase”?
Hey @Peter_Kalrsson
No unfortunately not. Tried it before ![]()
New app update (live: 2.35.5):
Changelog:
1. FIX: error handling for Homey 7.4.1
2. FIX: auth token
Thanks for fixing @martijnpoppen ![]()
New app update (live: 2.35.6):
Changelog:
1. FIX: 7.4.1 error reports
FYI: all these fixes are for the new release of Homey 7.4.1
Since 7.4.1. Homey actively logs errors which happens somewhere in the application. The app doesn’t crash but it is bad practice to leave those errors. So when I get new logs I’m updating it so the application will be “error free” ![]()
I’m sure I speak for many, but your efforts are second to none, your pro active nature is wonderful
Thanks a lot @Philip_Montgomery ![]()
Hi Martijn,
Het is gelukt! Achteraf snap ik niet wat ik fout deed… maar het werkt dus
Bedankt!
Martijn, there is a alam status “uit” end “uitgeschakeld” how come? This is the same end whit the homebase en flood cam there is always one status that is not usable. Also a question staus custom 1,2,3 could we name them? Ore wy dos this not get the same name in homey like in eufy app?
Thx! ![]()
Uit and Uitgeschakeld is because the Keypad has a different option which is Uit.
That’s why they are both there.
For the names It’s not possible to dynamically name them (in Homey), that’s why I called them custom
I use the keypad, can you explain how this should we used. The keypad is not a fisical device in homey…
Met vriendelijke groet,
Yannick Eeckelaert
When you press Uit on the keypad it will trigger the Uit on your Homebase
Ho ok,
End stil no way tot make it a fysical device? En show the status just whit the devices were it for?
Thx for the quick reply martijn!
Yannick Eeckelaert
@Yannick_Eeckelaert
The keypad has no function. Only setting a different security mode. Which you can catch with the Homebase. So adding it to Homey is possible but you can’t do anything with it.
I can look into the security modes if I can dynamically assign the values based on the devices you paired, but not sure if that works. ![]()
Would be great to see it in homey ![]()
Would be great to look into.
Yannick Eeckelaert
Sorry if this has been up earlier in the thread but I haven’t found anything.
Is it possible to get the Homey to override the Eufy app?
I have an indoor cam and a Eufy cam 2C.
I want to receive notifications when I’m away from home or between 10:00 PM and 08:00 AM if anything happens.
Otherwise I don’t want to have any notice since I’m home.
I don’t want to go into the Eufy app every time to change modes betwee home and away and I don’t want to use the geo since it need to have the gps active all the time.
I know how to do the flowcard in Homey but can Homey some how override Eufy?
