[APP][Pro] Eufy Security
New app update (test: 2.4.0 ):
NOTE:
During the work on the new library I found out that the new library isn’t that different from the library i’m using now.
With the last fix for the Homebase I already changed things in the library which makes a lot possible.
The new library has support for streaming, but with the limitations of Homey it’s not possible to use it.
Conclusion: I put the development for the new library on hold and improved the old library to support a lot of new things.
Changes:
  • NEW: add eufy-homey-client as LIB (modified the original library)
  • NEW: add Homebase trigger alarm ON with a duration (combine with other sensors e.g: Aqara)
  • NEW: add Homebase trigger alarm OFF (to stop before duration)
  • NEW: add Homebase flow card when the alarm turns on - (@Heula @Z_B )
  • NEW: add quickresponse for wired doorbell (@Rens_Hoekema)
  • NEW: add reboot flowcard for Hub based devices (Homebase or stand-alone camera’s)
  • NEW: message when device is initializing
  • FIX: improved battery update interval
Currently in progress:
  • [Feature Request] filter devices when pairing - IN PROGRESS
  • [Feature Request] Night Vision switch - IN PROGRESS
  • [Feature Request] HDR switch - IN PROGRESS (@Crashy)
Full to-do list: [APP][Pro] Eufy Security - #3 by martijnpoppen
