[APP][Pro] Eufy Clean
@Martien_Kop There’s no device in your account.
- Install this app on your Homey.
  • Add a device.
  • Login with your Eufy Account. After this I get the message “no new device found”
I’m using the new eufy app. The C28 is only working with the new app. Is that the problem?
@Martien_Kop no that’s not the issue. It just that the API doesn’t report any devices in your account. Are you using your main Eufy account ?
I think so. I’m using the account with which I start my Eufy App from the apple App Store.
@Martien_Kop can you try sharing your Robovac with another account and check if you can login with that one and see the device in Homey?
i made another account. same problem
@Martien_Kop please send a new report
@martijnpoppen
Together with Codex, I fixed scenes for at least my C20 vaccuum cleaners. I can now select the scene names directly in Homey which is much better than the 10 scene guessing work.
I have no idea if this works for the other models aswell but it should work with al MQTT models.
My fork:
Maybe you can use it for the app itself?
In also added local room cleaning support for my Tuya bases L60 model but I doubt you want to add that
@Kyle_Michiels nice! Can you make a PR ? Then I’ll integrate it into the app.
Local support I removed as that’s really limited and new devices don’t support it anymore
Its 2 PRs one for the Eufy SDK:
And one for the actual homey app:
@Kyle_Michiels thanks will check !
Hi Martijn,
Got a question. Does the homey eufy clean app work when I add my current working E25 and E28 robots to the new Eufy app instead of the Eufy clean app which seems to become EOL?
@Frank_Verschoor the Eufy apps are the same. Just a different UI.
But at the current moment the E25 and E28 are not compatible with Homey
Eufy once again changed their protocols and API
Maybe so but It seems that both Devices are still linked and visible in the homey eufy clean app and I still can see their active state…
@Frank_Verschoor in that case good that it works :smiley:
I have the E18 lawn mower, which I believe isn’t supported yet. Is there any way I can help get it supported?
@MRK no currently I don’t expect it it can be supported
It’s a new api which can’t be decrypted at the moment. Same goes for some new Robovacs
So don’t really see a solution yet. Unless you know how to decrypt it
Thats a pitty then. I don’t have the knowledge unfortunately to decrypt it.
Best I can do is to contact Eufy support.
@MRK eufy doesn’t give any support on 3rd party integrations
