Just did:
6067aac2-c54e-4401-bfd8-4309996079df
New app update (
TEST: 2.4.1):
Changelog:
NEW
1. NoneFIXES
1. FIX: repair device didnt show login popupSee supported device list: [APP][Pro] Eufy Clean - #3 by martijnpoppen
More - apps - Eufy Clean - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → Eufy Clean | Homey
@Kyle_Michiels repair should show a login now
(make sure to install the test version)
Thanks!
However I am running in an intressting issue.
I have 2 C20’s “Slaapkamer Zuiger” and “Stofzuiger onder”.
But for some reason “Slaapkamer Zuiger” has less funtionality?
Screenshots attached:
Advanced settings for “Slaapkamer Zuiger”:
Advanced settings for “Stofzuiger onder”:
And send a new report:
45660d99-7da8-44c2-b159-24438be3fe16
For the regular app, not the test app.
@Kyle_Michiels try a restart of the app and see if it shows the same. on restart the capabilities are added
After reinstall the app 3 times it finally works again!
Is the only difference between the main release and the test version the updated repair?
@Kyle_Michiels yes correct that the only fix
@martijnpoppen, first of all thanks for creating the app. I use now a variable so I know the cleaning was longer than 20 hours ago. But in the app I see information like “In Dock“ and how long ago this variable was updated. It would be nice if we could use this in the then statement with some logic, so we know when the last cleaning was.
@Jelmertje you can use the flow cards of this app and then set a variable.
in what flow can I find the logic of something like the time of the docking?
@Jelmertje you have to make the logic yourself.
There are enough flow cards which indicate that the status is changed. Based on that you can set a logic var yourself.
But according to your first message you already do that
I’m not going to add such logic to this app.
Hello Martijn,
I love your app and the automation is working great.
I only have two issues and i am not sure if you can help me.
I use in the automation the flow to set a to vac & mop, cleaning level and water level. Whwn i check the eufy app there apears a different setting, like instead of medium water it is set to low. have you ever faced this issue?
The second question is about the flow then set scenes and there are 10 scenes, where can i config the scenes?
Thank you very much for your help.
Cheers
Jerome
- Yes also experienced that, that’s a issue with the decryption of the message, unfortunately can’t be fixed
- Those scenes are the presets you can make in the Eufy app your self. After that it’s trial and error to see which number is equal to the scene you created in the Eufy app
Hi @martijnpoppen is there any update on lawnmower support (E15)?
Would be awesome!
@mbnn no no updates unfortunately still waiting for the sample
Hi Martijn,
Just wanted to let you know that the app crashes quite often, but after a restart everything works again
b1b85f52-dcba-4123-842a-59ac5a8253b6
Vriendelijke groet
Mark Stevens
I don’t know how much work it would be to have the Eufy app recognise the scene name that we have labeled and have it appear in the dropdown in place of selecting 1-10 and guessing. I have a feeling that every time we change something, the order gets reshuffled.
@Ken_Hansen as already mentioned in the post you referring to
It’s not possible to do that both Homey and Eufy limitation
Hi @martijnpoppen ,
Thanks for all the effort you put in. My C10 (T2292) does install correctly but after that does not update the status nor respond to any flow command it gets. I have created a diagnostic report in the app. Should I share the ID here?
Cheers!
@pmilten thanks
Yeah this was mentioned as well last week via a report. However I’m not sure if this can be fixed
Eufy seems to have changed stuff again…
Have to investigate as well
